This Could Only Happen To Me...
Old 11-28-2005, 10:59 AM
ehirst83's Avatar
Default This Could Only Happen To Me...
I was torquing my head down yesterday and it felt a little rough for 22 ft. lbs. I got all the large bolts done and went to finish the top 10mm bolts and snapped the first one off. I checked my piece of **** torque wrench against my buddys. Oh yeah it was way off. Hopefully once I pull the head I can get the broken bolt out. I just want this to be done I miss my car.
Old 11-28-2005, 12:41 PM
iamsickofitall's Avatar
same thing happened to me when i was doing my heads. i found out my brother was in the habit of tightening and loosening bolts with my torque wrench
i was lucky tho...when i pulled the head, about 1/3" of the bolt was sticking out of the hole so then i just went at it with some vice grips and got it out in no time...what an inconvenience tho.
good luck with yours
Old 11-28-2005, 01:15 PM
ehirst83's Avatar
That's what I'm hoping to do as well. When I broke off the bolt it only broke about a 1/2 inch off so hopefully it's sticking out above the deck. It just sucks I had to buy a new set of head bolts.
Old 11-28-2005, 01:19 PM
777's Avatar
This is somewhat of a common problem. I don't think I'd recomend anything other than arp head studs.
Old 11-28-2005, 01:32 PM
01350ss's Avatar
^thats why I'm buying a set of studs for my winter project
Old 11-28-2005, 01:37 PM
sounds like you should be alright with getting that bolt out - i'd say mine broke off about the same.
Old 11-28-2005, 02:54 PM
LostCauseZ06's Avatar
dude clair that really sucks man... sorry to hear that, hope you get her up and running again ASAP!
Old 11-28-2005, 02:57 PM
ehirst83's Avatar
Well I got a new set of head bolts and the rest of my gaskets today so she should be running again by Wednesday or so. Then I've got to break in my new clutch. I just can't wait to spray my wet shot for the first time with my new heads!
Old 11-28-2005, 03:18 PM
man im jealous.. i really really want mine back together!!
Old 11-28-2005, 04:09 PM
Black Z/28's Avatar
Just got mine last Friday! All of these 'broken bolt' posts have made me too nervous for bolts.
Old 11-28-2005, 04:23 PM
5.3litre's Avatar
what about arp "head bolts" are they good..i know studs are but what about just the bolts..
Old 11-28-2005, 05:04 PM
eagleuh1's Avatar
Hell, if your torque wrench is off that much you're probably going to stretch ARP bolts or studs till they break also. Get it calibrated once in a while.
