Has anyone seen this before (cracked ringland)
Upon disassembly of my motor, I found a cracked ringland on #7
it was cracked in 2 places between the 1st and 2nd rings without any visible damage to the crown. Also found a small crack under the 2nd ring. No other pistons showed any damage.
Can detonation crack between ringlands and NOT damage the piston crown? Definately had severe blowby in #7
yes stock pistons but 100% N/A
the area above the 1st ring shows no damage. both cracks were between the rings and a small crack under the 2nd ring
I know what caused it
93 octane and -2000' DA with over 11.5:1 compression don't work out so hot
I just find it fascinating that the crown of the piston above the 1st ring didn't get hurt
Originally Posted by dug
Maybe the detonation hurt the bearings too.
*disregard the last edited thing in your post...I accidently hit edit instead of quote *
