What Cam CAn i use?
What Cam CAn i use?
YEa i own a 98 ls1 Camaro, does anyone know what the biggest cam i can use but i dont want to change out the valve springs and torque Converter
You allready have it.
you can go with any cam but that depends on the usage of the vehicle whether it as a daily use , street strip or a drag car , anyways its recommanded to change the vavle springs , push rods ...etc and also TQ converter in order to function in the right way and get every bit oh hp out of your motor.
The last advise I can give you is SEARCH SEARCH and SEARCH .
Originally Posted by DSRCAM
what cam would u recommend for a daily driver but also street racer?
And in an auto, change to higher stall, you'll benefit more than just any cam swap without supporting mods.
VIG 3200/TCI 3500/ Yank 3500 will get you at least .5 time reductions if you hook
I will advise you as predator mentioned to go bolt-ons, and when ever you get your cam choice . throw your matched stall with it , thats better than changing the stall again and again while you swap your cam.
