Does anyone rent out flycutting tools?
Old 11-30-2005, 10:26 PM
Okie02's Avatar
Default Does anyone rent out flycutting tools?
i know a company used to, but does anyone know of a company that still does..i was wanting to rent the tool and the special cylinder head that you need also..thanks..
Old 11-30-2005, 10:34 PM
DONAIMIAN's Avatar
LG motorsports.
Old 12-01-2005, 07:38 AM
Okie02's Avatar
doesnt FFHP or whatever they are do too?
Old 12-01-2005, 12:18 PM
waterbug1999's Avatar
Is there a "write up" on how do this?
Old 12-01-2005, 01:28 PM
MadBill's Avatar
i believe Iskendarian Cams does too.
Old 12-01-2005, 02:05 PM
DONAIMIAN's Avatar
I think they will let you rent the tool, but your still gona need a head with the valve seat removed, and I know LG rents all of that.
Old 12-01-2005, 02:21 PM
HavATampa's Avatar
Thumbs up
There's writeups on everything these days. Don't you just love the internet!
http://www.forcefedhighperformance.com/tech_Isky.htm
Old 12-01-2005, 02:23 PM
Louis's Avatar
We have quite a few "Dummy" heads that we use for flycutting. Much like any tool rental , we charge said amount, and refund ~ 75% of it back when you return the tool. I cant tell you how many people refuse to return it!
At anyrate, Give us a call- 972-429-1963. Mike, Anthony, or Bobby will get you squared away with what you need
Louis
Old 12-01-2005, 03:25 PM
SideStep's Avatar
You can also just buy your own from Thunder, I think mine was $140...
Old 12-01-2005, 03:55 PM
MadBill's Avatar
In desperate circumstances, when only modest stock removal was necessary, I've resorted to grinding 'teeth' into the faces of slightly oversize scrap valves and using them as cutters in an un-modified head...
Old 12-02-2005, 06:34 AM
GuitsBoy's Avatar
How did this work? I was going to do this but was having trouble finding the proper sized valve. My current plan is welding a piece of 1/4 inch steel plate to the end of a 6" 5/16 bolt, and turning it down to 2.125 on the lathe, then milling a rasp or coarse file like pattern on the cutter head. Ive got a small collar clamp to use as a stop against the valve guide to set cutting depth. Ill post pics when its finished.
Old 12-02-2005, 10:56 AM
MadBill's Avatar
It worked fine. (although I don't recall what the oversize intake valve was from.) For the exhaust in fact, much like you plan, I ended up brazing a small lathe tool bit across the head of the valve, set for the right diameter. I used a smaller valve so it would sit down inside the port, to clear the head at zero lift. In retrospect, it probably didn't need to be such a good alloy just to cut eight small moons in aluminum, but better safe than sorry...
