SCE Titan head gaskets--anyone using?
1 Post
Planning to buy some (stock bore), .043 thickness with F11, 5.3 TEA heads, ARP studs...anyone have experience? In particular, leakage issues? Thanks in advance...
1 Post
No, the block/heads are not o-ringed. I see these as an alternative to cometics, they are offered in the stock bore size and in varying thicknesses. Cometics have been known to leak, and wondering if anyone had better results from these. BTW, they cost less than cometics. Thanks.
Id like to use the regular SCE copper gaskets. You guys dont see a problem using the 4.060 bore gaskets on a stock bore motor do you? sorry for threadjacking. I do agree that these are a cost effective alternative to cometics when you want to run smaller than .054. Plus they say theyre reusable up to 5 times.
You have an o-ringed block or heads? If not, then I wouldn't bother with them.
Originally Posted by Beast96Z
Regular copper gaskets are prone to leak in street applications. They are very hard to seal up, plus o-ringing the block is highly reccomended. If you plan to street drive, I'd reccomend the Titans because of th esealant around the passages.
Originally Posted by Jimmy P
Can you elaborate a little bit on this? I don't have any experience with these gaskets, but I was planning on going with these when I get the ETP heads. I have read nothing but good things about them, moslty that they dont leak like a lot of people have reported with their cometics.
