f14\15 vs g5x4 vs ms3 vs trex
i have a stock bottom end, boltons, 3.73 gears 3500 stall.. which of these cams would give me the most power\accelration with a set of afr 205 heads....
also for any\all of these cams would afr 205's be the ideal head?
also im looking for a real nasty idle.. this car gets driven for fun only (mostly street raceing)
get ready for flycutting. I'm pretty sure none of those cams will clear with afr 205s. I run an X3 on a 112 and it is close in terms of PTV. Most of those cams will make a lot of power up top. Are you ready to spin to 7k? it can be done on a stock bottom end. My limiter is set at 6900 and I have a stock bottom. you will want a bigger stall. something in the 4000-4200 rqange.
Josh
LS1Tech Premium Sponsor
If the AFR 205s are unmilled they will clear with the MS3.
Brian
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
or to consolidate my thoughts im down to 3 ideas...
1: PRC 5.3L STAGE 2.5 HEADS WITH TSP 233\239 CAM $2400
2: FM 14 CAM AFR 205 HEADS $3200
3: G5X3 CAM AFR 205 HEADS $3100 (FLYCUTTING REQUIRED)
What I Like About The Tsp Package Is It Is Economical And Makes Ok Power From What Ive Heard
What I Like About The Fms Package Is I Percieve It To Be The Most Popular
What I Like About The Lg Package Is They Claim Ill Be Shifting At 6600 Rpms And That This Cam Is Capible Of 480rwhp (on A M6)
