Ls1 to Ls2 Block okay to do?
Old 12-05-2005, 10:44 PM
BadAssFast's Avatar
Default Ls1 to Ls2 Block okay to do?
Is Knock Sensor deletion from the program the only major difference in the two blocks...in other words..if I go ls2...edit out KS? What else?
Old 12-06-2005, 09:22 AM
GuitsBoy's Avatar
You dont have to remove the KS. you can relocate them to the side of the block and buy an extention. Also, the cam sensor is in the timing cover. Youll need the ls2 timing cover, timing set and sensor.
Old 12-06-2005, 11:53 AM
BadAssFast's Avatar
I'll check FAQs tonight thanks!! Same screw in sensor as on top? just screws in the side?
