? on clay method of checking p to v
Old 12-07-2005, 06:22 AM
tdrumm's Avatar
Default ? on clay method of checking p to v
Got a couple of questions on checking piston to valve clearance using the clay method.
1. What type of clay?
2. Should I check it with or without the head gaskets? - I'll be using .045 Cometics
3. If I don't use the head gaskets, do I just add in the thickness to the measurement I get?
4. What is the safe minimum clearances on the intake and exhaust?
Thanks
Old 12-07-2005, 08:26 AM
PREDATOR-Z's Avatar
1. What type of clay? Natural clay, not elastic
2. Should I check it with or without the head gaskets? - I'll be using .045 Cometics. You can do it without, but Cometic are reusable and you should use ARP bolts anyways, so i would put them on for a clearer picture.
3. If I don't use the head gaskets, do I just add in the thickness to the measurement I get? Yes compressed value
That is a grey area, I like .080 int/ and .100 exhaust for the street (kinda conservative, but I've never kissed my pistons)
Thanks
Old 12-07-2005, 08:42 AM
tdrumm's Avatar
Thanks a lot! And yes, I am using ARP bolts. Ever heard of anyone bottoming them out in the bolt holes with milled heads?
Old 12-07-2005, 08:51 AM
PREDATOR-Z's Avatar
No, but I've seen issues with later LS blocks (block thread holes not deep enough)
Old 12-07-2005, 01:42 PM
Dixit's Avatar
Yeap that being me when I put ARP Bolts in, called ARP and its a known issue they sell a special tool to bore the last threads that GM missed. But the tool costs over $100. Or they said you can safely grind a thread or two off the end of the bolt.
Dixit
Old 12-07-2005, 03:33 PM
MadBill's Avatar
Quote <2. Should I check it with or without the head gaskets? - I'll be using .045 Cometics. You can do it without> End quote
1.Don't the truck pistons come above the deck like other LS engines? If so, it's not going to crank over with no gaskets.
2.Besides, theres less chance of getting a 'negative clearance reading' with the gasket in place.
3. And once the piston/deck is measured, perhaps a thinner gasket would be good for squish and compression ratio.The forum consensus is that 0.030" clearance is plenty. safe.
Old 12-07-2005, 03:40 PM
ssheets's Avatar
Clarify, that's .030" quench, not P to V. Predator was talking P to V.
Quick Reply: ? on clay method of checking p to v
