Installing a cam and advancing it
Wondering if there is a general rule of thumb for advancing a camshaft during installation and how many rpms it brings the power band down.
Keep in mind that it will also close your intake valve earlier resulting in an increase in DCR. For most, this change will not be significant enough to matter, if you are already experiencing a detonation problem due to compression ratio - advancing the cam will make it worse.
