shooting for 400!
Old 12-15-2005, 01:42 AM
XtremeDime's Avatar
Default shooting for 400!
igot a 99 xtreme thats getting an ls1/4l60e and i think im look for like 400 hp out of it. i was thinking a good cam and some work on teh top end, i dont know if aftermarket heads are in the budget but would ls6 work good?
Old 12-15-2005, 01:53 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Yeah, sounds like you are off to a good start. LS6 heads and a decent cam with full boltons would definitely get you the 400 mark. What type of stall and rear end are you going to end up with?
Old 12-15-2005, 01:57 AM
XtremeDime's Avatar
i think im gonna stick with my stock rear for a little while maybe upgrade it. its already got a GU80 posi. i was thinking around a 3000 stall, would i need a built 4l60e or would it hold up stock? can u explain to me the stall?? i think its when you put your foot on the brake and it doesnt spin until u hit 3000 rite?
Old 12-15-2005, 01:59 AM
XtremeDime's Avatar
would an ls6 cam be decent enuf or would i need like a comp cam? i want something that i shouldnt have to modify for clearance? ya know?
Old 12-15-2005, 02:05 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Here is a good explanation of a stall or torque converter.
http://www.bankspower.com/Tech_under...rqueconver.cfm
As far as cam goes, there are many different manufacturers. You might check sites like SDPC or Thunder Racing for some good profiles. You might be able to get a good deal on a used one on here, if it is a hyd. roller then it will not matter if it was used unlike a solid roller. Good way to save money as well.
I don't have a clearance problem on mine and the are milled .030
244/248 .598/.598 115
Old 12-15-2005, 02:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you are going for the 400 mark I would go bigger than the LS6 cam or a Z06 cam for that matter. Something in the 224-228 range would definitely be a good route to check out. Plus you shouldnt have clearance problems unless you are thinking of going 24x's and 600+ lift ie:T-Rex, MS3, G5x3 and 4.
Make sure that if you do go fairly big or just mild for that matter that you upgrade your valvetrain to avoid unwanted problems/damage. I would suggest that you run dual springs with if you can afford them titanium retainers and some hardened pushrods. no need to replace rockers or lifters...they will get the job done.
Old 12-15-2005, 02:20 AM
XtremeDime's Avatar
would exhaust also help? im running no cats and true duals i dont know which muffler would be best tho. i was planning on upgrading teh valvetrain with comp cams stuff so no worries there.
Old 12-15-2005, 02:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
werd up on the exhaust. that is what i run. what size are the pipes you have? 2.5 or 3'? any bullet muffler would probably get it done. just depends on how much you want to spend. With a cam you are gonna want to have a good flowing high velocity exhaust. You will get more out of your cam/heads.
Old 12-15-2005, 02:27 AM
XtremeDime's Avatar
thinking 2.5 side exit before the rear wheel, since my gas tank is on the otehr side i cant really run it out the back easily. would port and polishing the heads help at all? or are they at max flow already. any kinda intake manifold ud recommend? thanks for the replies you are pretty much the only who would respond to an s10 lol
Old 12-15-2005, 02:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
lol!
Yeah if you can get a good port job on those heads it will be worth it IMO. If you were looking to up the CR you might look into getting them milled to achieve 11.1 or so. You will definitely want to look into getting an LS6 intake or if you can afford it the FAST. I am gonna be honest, the 90/90 setup with the intake TB combo seems to be the route that 90% of the folks I know are leaning towards if not already running.
wait...your an S10?
Old 12-15-2005, 02:35 AM
XtremeDime's Avatar
wats the 90/90 setup? the 90mm tb? i heard that hte lsx werent worth the money. would porting the manifold help at all?
Old 12-15-2005, 02:37 AM
XtremeDime's Avatar
wats CR?
Old 12-15-2005, 02:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It all depends on if you are trying to get all you can out of the motor. LS6 will work just fine if you want to hit the 400 mark and call it a day. If you are shooting for the 430+ range then a ported FAST may be worth it. They are only worth it if you are willing to pay it. I am glad I got mine over the LS6 honestly. It gives you a chance to do port work on them in the future or you can easily slap a direct port setup on them as well.
CR = Compression Ratio
Old 12-15-2005, 02:46 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
90/90 is the intake and tb combo yes.
LS6 is 75-78mm i believe. not too sure.
Old 12-15-2005, 02:55 AM
XtremeDime's Avatar
to be honest i dont know waht the hell i want lol. with 400 rwhp wat would i be looking at in the quarter mile?
Old 12-15-2005, 02:56 AM
XtremeDime's Avatar
i want it to have a nice idle that screams "try me, Mr. honda" i want some nice mid range power that is still streetable maybe just barely.
Old 12-15-2005, 03:02 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well I can help you out a bit...answer these.
Are you wanting to spray your truck?
Have you thought more about getting a turbo or supercharger over heads and cam?
Nice mid range ehh?
well I ran a cam that kicked in around the 2200 mark and pulled pretty far up there. 222/226 .566\.569 114
Worked great, but I wanted a cam that said "F U" so I went wild with the 244/248
Old 12-15-2005, 03:04 AM
XtremeDime's Avatar
i thought about maybe adding a remote mount turbo under my bed later on. i dont like nitrous seems incredibly cheap to me. maybe a little higher 2200 like 3000 or so would be nice. how did the idle sound on that?
Old 12-15-2005, 03:06 AM
XtremeDime's Avatar
actually i want something that keeps pulling when im going 160 lol.
Old 12-15-2005, 03:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well the idle on a 114 is fairly tame but that cam had a little bit of chop to it. I mean you can tell that it had one for sure. Are you looking for a mean idle or something that is more of a sleeper?
Get a top end cam if you plan on going 160...lmao!
