Z+220 cam
The guy from SDPC said that the Z+220 would make more power than the Hotcam which is what I was originally goin to go with. Thats why i would like to know if anyone has had any experiece with it. I also got a set of heads at home that I am getting ready to have some port work done to them.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well if you were gonna go over .550 lift I would say that the Comp 918's would be a very sound plan for ya. hardened pushrods are a great idea too. LS2 timing chain will be the best bang for your buck. The double rollers are a really pain because they are fairly tight and cost 3 times as much as an LS2.
!LS1 11 Second Club
That Piece of Sh*t Hotcam actually makes some pretty stout numbers, along with a great tq curve. Usually between 370-385rwhp... for an antiquated, .525 lift cam- that's pretty damn good.
The 220 cam will probably be easier to tune and be easier to drive with, but I'd be hardpressed to say that it will make more power than the Hotcam.
Either way, I'd look into the venerable TR224. Valvetrainwise, people are using it for 30-40K miles on one set of springs (checking them periodically would be wise).
TR224 is proven. Get it on a 114 and it's very DD friendly. Get it on 112 for some lope, and you still won't sacrifice DD.
!LS1 11 Second Club
Originally Posted by blkbird
Is that with all the bolt ons I assume? So between the two the hotcam would come out ahead?
Out of the two, the TR224 comes out ahead.
(Speaking from experience- went from a 222/222 cam to a 231/237 cam- you're always gonna want more). 224 is a great benchmark.
And to answer your question, if you're gonna tune and like a choppy lope, Hotcam (blasphemy!) it would be.
220/224 Cam
I have the Vinci version of that cam and love it. Numbers in the sig. Once I replace my clutch, I am going to dyno again (now its cool here in FL) and get some track times.
