Desired Compression ratio for nitrous???
Old 12-15-2005, 11:03 AM
LostCauseZ06's Avatar
Default Desired Compression ratio for nitrous???
alright my 408 is going together finally and im wondering what i want my compression ratio at??? im going to be spraying a very healthy amount... the pistons are an 8 cc dish, zero deck, 64 CC heads, 4.030 bore, 4" stroke..
this puts me at 11.4:1 with a .040 cometic gasket and at 11.11 : 1 with a .051 gasket..
another thing... the advertised gasket thickness.. is that a squished thickness or before torquing thickness??? i wanna keep a good quench so what would be the better decision for me??
help ASAP would be appreciated... im ordering them up today!
Old 12-15-2005, 11:35 AM
itchygomey98's Avatar
I'm thinking that quench is a little high. There's a pretty good thread on it in this section. With 0 deck, I would think a .040 cometic would be a better choice. I don't think you'll have a problem with 11.4 as long as the cam you decide on will complement it.
Old 12-15-2005, 02:42 PM
im just wondering if the nitrous is not going to like a little extra compression... the cam is a 240/246 608/613 on a 110+2 LSA
put down WICKED power on the juice..
Old 12-15-2005, 02:45 PM
777's Avatar
Nitrous and compression go hand in hand. 11.4 sounds perfect to me. Make sure you have a good tune.
Old 12-15-2005, 02:52 PM
i will will be dyno tuned for sure..
