sewing machine noise?
Old 12-16-2005, 08:24 AM
jlashley2001ss's Avatar
Default sewing machine noise?
Just wondering if this the same sound that people talk about after getting Long Tube headers installed?! Mine has the ticking sound after Pacesetters installed(and I do have restrictor plates put in if that matters). Just want some info on this. Thanks
Old 12-16-2005, 08:30 AM
Turo's Avatar
I had a slight sewing machine noise after headers. It got a lot louder after the cam though.
Depending on how loud the tick is, it could also be an exhaust leak.
TAQuickness's Avatar
sounds like an exaust leak. Double check the headder bolts are torqued to spec and that none of your flanges are leaking. FYI seafoam makes it real easy to track down an exhaust leak
iamsickofitall's Avatar
you will notice more noise after a header install - remember...those heavy, thick clunky manifolds you pulled off deadened the sound more
Old 12-16-2005, 08:44 AM
yeah true. I had my exhaust guy check for leaks and he said there wasnt any. I also had the dealership clean the car up and tighten header bolts if needed. So maybe its just loud ticking valvetrain noise.
Also how would the seafoam track it down?
Old 12-16-2005, 10:24 AM
ttt guys. any info on this is greatly appreciated
Old 12-16-2005, 10:37 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Sea Foam, sent through the intake manifold via the brake booster line, will produce a big smoke show in your exhaust as it burns all the crap outta your engine. If you have any exhaust leaks, you'll see smoke coming from there too.
Old 12-16-2005, 10:43 AM
how do i go about getting and putting this stuff in?
Old 12-16-2005, 11:09 AM
MeentSS02's Avatar
Go to your local auto parts store, and ask them if they have any Sea Foam. It comes in a plain looking bottle, and has about a million uses listed on it.
Follow the directions on the bottle. Your brake booster line is the easiest way to get it in the intake.
Old 12-16-2005, 11:19 AM
am i suppose to change oil afer doing this?
Old 12-16-2005, 11:35 AM
MeentSS02's Avatar
Yes you are.
Old 12-16-2005, 12:08 PM
zamboxl's Avatar
dont worry about the tic mine does it all the time and it drives me crazy, but the car is fine makes desent power, it dynoed at like 385 to the weels, with a 224 tr cam and pp stage 2 heads with the stock y pipe plus headers, and no cats, still on ls1 intake.
Old 12-16-2005, 11:09 PM
jcgardnr's Avatar
I have a ticking noise that might sound the same. I have a sound clip that I created of it, but I do not know where to post it. Can someone tell me where I can post it? I want to see if this is the same noise some of you have.
Old 12-16-2005, 11:11 PM
PSiBlackZ's Avatar
mine does this too, but its strange it will do it right before she is do for an oil change. also it will only do it for about 5 min, until the engine warms up.......
Old 12-17-2005, 12:10 AM
that sounds like piston slap brother!
Old 12-17-2005, 01:31 AM
PSiBlackZ's Avatar
ehhhh, i hope not, i know my ****, and i think it is a lifter problem...... anyone agree with me, these ls1's will "recalibrate" themselves sometimes(explains why it goes away after a few minutes).. anyways when you pop the hood it is clearly coming from the head, advice????
Old 12-17-2005, 10:03 PM
itchygomey98's Avatar
Recalibrate? Nope. Ticking could be a lot of things, but if it goes away after warming up that could be an indication of piston slap which is plenty common in a stock LS1.
Old 12-18-2005, 12:29 AM
BlackHawk T/A's Avatar
Piston slap isn't a ticking sound...its a knocking sound.
Old 12-10-2007, 01:17 PM
joshua022's Avatar
I read somewhere on here that you could use slightly shorter pushrods to reduce some preload on the lifters and make it a little bit less like a sewing machine. Is that correct?
Old 12-10-2007, 04:56 PM
02 wife's Avatar
My car is ticking after a kooks longtube install but it sounds like its in the valvetrain!
