98 a4 ls1 corvette question...
Old 12-17-2005, 01:26 PM
s346k's Avatar
Default 98 a4 ls1 corvette question...
where is the dipstick for the transmission?
Old 12-17-2005, 01:58 PM
s346k's Avatar
somebody respond...anyone?
Old 12-17-2005, 02:15 PM
LSXRX7's Avatar
i believe that the transmission is in the back as a transaxle
Old 12-17-2005, 02:21 PM
s346k's Avatar
ok, so how do we check the fluid level?
Old 12-17-2005, 03:13 PM
Restricted User
crazykid's Avatar
There is a plug on the side of the tranny pan. To check you need to have the car running and then the plug needs to be removed. If there is fluid coming out the hole then there is enough fluid in it, if not then you need to add enough Dexron/MerconIII until it starts to come out the hole.
Old 12-17-2005, 03:28 PM
s346k's Avatar
wow, that's pretty shitty. i guess they have a sensitive sensor or something to indicate how much fluid is in it?
Old 12-17-2005, 03:40 PM
ToplessTexan's Avatar
Yes, it's a pain. They are fussy about having the fluid level just right.
