valve drop
Old 12-19-2005, 11:28 AM
stalker's Avatar
Default valve drop
hi, i have a question for ya, beside to take all plugs out and rotate the crank bolt. is there any more ideas on this? its one of the intake ones, and the back driver side. any info. would be great besides pulling the head. thanks mike
Old 12-19-2005, 11:52 AM
napoleon's Avatar
did they fall all the way down into the cylinder? how far away from TDC is that cylinder when it dropped?
Old 12-19-2005, 12:11 PM
ChucksZ06's Avatar
If the valve tip is still in the guide I would get a strong magnet on the tip and if you cannot pull it up with that alone you might be able to carefull turn the engine until it bumps the head of the valve to help it up the guide.
good luck.
Old 12-19-2005, 01:00 PM
SgtB's Avatar
good luck.
this is a good suggestion....
also try to use an airhold to fill eeh cylinder up with air and pop it back up...this will only work if the valve hasnt dropped completely into the cylinder
Old 12-19-2005, 01:45 PM
GuitsBoy's Avatar
Its my understanding that the dropped valve will hit the cylinder wall before the stem falls all the way out of the valve guide. That being the case, youre on the right track, slowly rotate the crank till the piston starts to push up on the valve, you may need to rock back and fourth on the way up so the valvestem doesnt bind up crooked. Removing spark plugs will make it easier to spin the motor, but probably not necessary. I dont know what stage of undress your motor is in, ut you may not want to get to the pasky #8 plug. Also, I dont know if a pen magnet would be strong enough as mentioned above, but it couldnt hurt to try.
Old 12-19-2005, 02:10 PM
MadBill's Avatar
You might try also the high tech approach of a bent stiff wire down the sparkplug hole...
Or even a rubber hose fitted snugly over the guide and connected to manifold vacuum on another vehicle.
Old 12-19-2005, 04:06 PM
Brains's Avatar
With the stock LS1 (3.898") bore, the valve will hit the cylinder wall. With a 4.030", that ain't the case - guess how I know
Old 12-19-2005, 06:22 PM
GuitsBoy's Avatar
Sounds like somebody isnt using big enough valves in a bored out motor
Old 12-20-2005, 12:30 AM
stalker's Avatar
hi, well just wanted everyone to know thanks i got it to come up and wanted to say thanks for all the advice you all gave .thanks once again for all your help..mike
