polishing combustion chambers?
14 Second Truck Club
What are the benefits of polishing the combustion chambers besides looks? When I get my heads done by patriot, I'd like for the chambers to be polished. Doesn't it help with carbon build-up and surely it helps a little with the flow?
Quite often, more is to be gained by paying attention to the chamber than to other "high profile" things like port matching. If you have the opportunity to do it / or have it done - go ahead. It helps to reduce turbulence, avoid hot spots and slightly slows the build up of carbon.
