Cam swap, need help
Old 12-20-2005, 09:03 PM
MetallicaMatt's Avatar
Default Cam swap, need help
alright guys, i offically started my cam swap tonight
I figured i would start a thread so i can just put up my posts of questions all together
I have the drivers side coil packs off
i have all but one of the bolts from the passenger coil packs off...except for that last one way in the back. i can't get on it straight b/c of the big rubber hose right there. i think its for the A/C??
i've been fighting that one bolt for at least 30 minutes, and if that rubber hose wasn't there, i could probably pop that socket right on.
can i disconnect that hose? or no no no b/c its a/c or something? or spill coolant all over my engine bay
thanks guys
Old 12-20-2005, 09:14 PM
LS1TECH Sponsor
Katech_Jason's Avatar
You're probably being blocked by the A.I.R. injection hose. Check to see that it leads to the header and disconnect it.
Old 12-20-2005, 09:17 PM
i have offroad headers on the car, I took my A.I.R. system off the car
Old 12-20-2005, 09:23 PM
ss rally red's Avatar
Maybe? But I think hes talking about the hoses going to the heater core? I have done almost 40 cam swaps on these things and that rear bolt is the #2 PIA after the radiator. If you swap in the car a bud with the right size prybar, can press on the top hose and squeez just enough pressure to get a 1/4 drive 10mm on there NEVER reinstall
Old 12-20-2005, 09:32 PM
yeah i followed the hose, looks like it goes to the heater core
so i don't really want to unplug it and get coolant all over everything
i guess it'll have to wait until i get someone over to help push that hose back
Old 12-20-2005, 10:39 PM
CUJO98TA's Avatar
gear wrench!
Jeff
Old 12-20-2005, 11:29 PM
if worse comes to worse, can i detach that hose?
Old 12-20-2005, 11:34 PM
TAQuickness's Avatar
Look up ^^^ one post. You really should call it a night and pick up a set of gear wrenches in the morning. Sears might even have them on sale.
Old 12-21-2005, 09:19 AM
i saw that, but i don't think i can fit a gear wrench down there with room to move
i'm having a friend over later, so we'll see how it goes
Old 12-21-2005, 09:35 AM
01formula6's Avatar
gear wrench with a flexible head, makes it like 100x easier.
Old 12-21-2005, 11:07 AM
AdamSS's Avatar
It is a pain in the a$$ ! Took me a good hour just to remove this one bolt !
Word of advice, once you have that one off, don't ever put it back. You don't have to. You haver other three holding the coil packs just fine.
Old 12-21-2005, 11:41 AM
hurm, the problem is that i can't get the deep well socket to sit on the nut, b/c the hose isin the way to let it sit on the bolt straight
Old 12-21-2005, 11:48 AM
01formula6's Avatar
See the above advice, if you don't go buy a gear wrench you will spend a long time screwing around with that bolt and end up with some cut up hands.
Old 12-21-2005, 12:08 PM
yeah but i still don't see how that will help me get the socket seated on the nut. i can't get it on there with just the socket alone
also, i diconnected my power stearing cooler line that runs into my radiator hose. i think its just oil, how do i tap off what little bit came out? Is that all take care of when i change the oil? Or is it in a separate fill spot?
Old 12-21-2005, 02:02 PM
nobody had a gear wrench
i can't get that f*cking bolt out! i tried pulling the heater core hose off but i can get pliers back in there to undo the clamp. just tried pulling it off...that didn't work either
f*cking cars
Old 12-21-2005, 02:11 PM
LC
LC's Avatar
can you take a pic?
i took that bolt off with a 1/4 ratchet... there is space.. maybe your hands are too big
Old 12-21-2005, 02:25 PM
no digital camera. i'm just 3/8" drive. i guess i could try the 1/4", i'll have to find adaptors and stuff since everything i have is standard lol
i wish my hands were too big! i have tiny hands..but big feet? who knows what the hell thats supposed to mean...small gloves and big socks i guess
Old 12-21-2005, 02:46 PM
PREDATOR-Z's Avatar
HOBBIT??
Just kidding mman, be patient, you'll get through it.
Old 12-21-2005, 04:34 PM
welp i've still been ignoring that last bolt, bc i know i'll get pissed off again lol
water pump is off and i just took the pulley off
Old 12-21-2005, 04:55 PM
WsSickLs6's Avatar
don't get gear wrenches...they suck
get a set of ratcheting wrenches from snapon...
a stubby w/ flexible head sounds like it would be dope right now
