Pushrod length with new heads/cam
What length will I need?
TR230
Patriot Stage II 243's
PP Gold Dual Springs, Ti Retainers
Stock Lifters, Rockers
Hope this doesn't end up sounding like a sewing machine!
Thanks
TR230
Thanks
Unmilled I would run 7.425 (quieter option)
Or mill the heads .010 with .054 gasket and 7.40
Or run .045 Cometic, unmilled with 7.40
Check PTV with bottom 2 options
Why would they be harder?
You have to take into account that your cam base circle is smaller. I'm speaking from experience in using them myself
yeap Comp cam. TR has them, it is where I get mine from..
Originally Posted by vettenuts
Why not measure them and make sure? Skoggin-Dickey has the Manleys in every length known to mankind, so your options aren't limited although Thunder Racing can probably get you a different lenght as well.
You've received some good advice so far, but the only way to know for sure is to measure. You can get adjustable PR's for about $20. Cheap way to find out for sure.
