cam install suggestions
i have a 2000 camaro ss with 70,000 miles on it with just bolt ons right now and i am looking to get a magic stick v3 installed in it. if i purchase the install kit from tsp which includes Camshaft, Comp PRC Spring Kit, and Hardened Chromoly Pushrods, what else do i need to get besides a good tune? thanks
Also some basic tools to do the swap. You need some pen magnets or lifter rods to keep the lifters from falling. You also need a pulley puller and a deep well 24mm 6point socket to remove the bolt. And like the others said, ls2 chain is good, oil pump, and a basic cam bolt and gasket kit which you can guy from TSP as well.
that is a very good deal i ordered mine the other day. but i would suggest a ls2 chain, ported ls6 pump, oring, w/p gaskets, front cover gasket, front cover seal, new plugs, and 6 qts oil and filter. all the correct tools such as a pulley puller, 5/16" dowel rods, and such.
