1.7 vs 1.8 Rockers
You will get obviously more lift and also more "valve duration".
Your springs will also feed more load back to your lifters and need to keep up with this faster accelerating valve and valve spring movement so the demand will be greater. What are the cam specifications and what springs are you running (spring part #, seat pressure)?
