ls2 heads and MS3
Old 12-26-2005, 09:24 PM
ReD_Z28's Avatar
Default ls2 heads and MS3
hi every one i am about to get some ls2 heads stock out of new C6 the are used lil(good price).i was thinking if the ms3 would clear and do i need the 7.35 pushrods or the 7.40 the would be fine ?
Old 12-26-2005, 09:33 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I would say that the 7.4's would work unless the base circle of the cam is different or the heads are milled.
Old 12-26-2005, 10:55 PM
PREDATOR-Z's Avatar
LS2 243 castings will clear the MS3
Most shops will recommend 7.40.
I would run 7.425's and if you have more than 50Kmiles on your lifters, I would change those too.
ReD_Z28's Avatar
i would not mile them with the MS3 ,so you think the should work fine if the are not miled i have every thing i just wanna be sure that the would fit with out PV issue .
Old 12-26-2005, 11:06 PM
ReD_Z28's Avatar
I know its long store but I thought that the ls2 head the are no more than ls6 heads and the should fit with the MS3 with the stock push road length 7.4 .but you know with that size of cams it is allows better to ask .i bought the whole package for the ms3 the titanium returns and the dual valve spring push road and oil pump but I got these heads offered for very good price and I couldn’t resist that. I will be using stock GM gasket to Increase PV clearance .thanks for the help
Old 12-27-2005, 12:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If they are not milled you wont have a problem.
Old 12-27-2005, 12:56 AM
Juice Junkie's Avatar
The MS3 is a sick cam....You are gonna need a GOOD set of ported heads to really get the most out of the cam.... Out of the box, or stock heads wont cut it....You will be leaving alot on the table... TRUST ME.....
Old 12-27-2005, 08:20 AM
ReD_Z28's Avatar
I know the ms3 cam would benefits from the ported heads, but I think with the ls2 would be killer setup for the price and better then the stock head casting, even that the c6 heads exhaust valve is not sodium filed but I think the power will be in the range of 420rwhp maybe not sure but that is my Target .
Old 12-28-2005, 07:15 PM
REDSS01's Avatar
My set up-stock LS2 heads+F13=417whp 397wtq SAE/427whp 407wtq Standard
Old 12-28-2005, 09:52 PM
ReD_Z28's Avatar
Nice numbers man considering how cheep the are now days.
Old 12-28-2005, 11:56 PM
ReD_Z28's Avatar
Bad luck the guy change his mind and he want sell them (he might use them later????) .I might ended up with 408 with 11:5 comparison ratio and a set of AFR225 fully ported by TEA, why wasting time and money in small step at time. I think the ms3 will remain in till the right time come's for the next mod .
Cheers for every one and thanks for the greet help.
