Anyone tried T-rex cam with Ported Heads?
Old 12-29-2005, 12:10 PM
SlickVert's Avatar
Default Anyone tried T-rex cam with Ported Heads?
Has anyone tried the T-rex cam with a Ported Heads?
If so, what Heads, valve size, compression, ect.
What were the dyno numbers and or track times?
Do you think that is to much cam for good Ported Heads?
Thanks
Old 12-29-2005, 12:22 PM
Fireball's Avatar
I ran it last year with a set of GTP S2 5.3L heads milled .040"
Made decent horsepower (460ish to the wheels on slicks). and ran pretty darn good for its weight (3350-3375 lbs)...
went 10.48 @ 129.8 in -100 ft air (on a 1.43 60')
also ran consistant 10.70-10.80s in summer heat (+3000 ft air)
WS6FirebirdTA00's Avatar
what do you mean by too much cam? if oyu mean p-v clearance then yes it prob is. ported heads would only help it flow better.
Old 12-29-2005, 06:42 PM
SlickVert's Avatar
Fireball
That’s a good ET (10.49 and 10.70 to 10.80 in +3000da)
What intake, gear and tire were you running?
What are you planning for 06?
WS6FirebirdTA00
When I said might be to much cam for ported heads, I meant that the T-rex was design for stock heads and with good flowing heads you might want a different cam.
Fly cutting would be a must.
Old 12-29-2005, 10:07 PM
they are designed for sotck heads but i imagine ported stock heads woudl also be kick ***
Old 12-30-2005, 05:50 AM
Fireball's Avatar
Originally Posted by SlickVert
Fireball
LSX 90/90 intake, 4.71 gears, and a 28x10.5W tire was the combo I used last year.
Next year is a change in heads, change in intake, and most likely a change in cam (optimized for my heads and induction)
Old 12-30-2005, 09:44 AM
scalemaster's Avatar
I have some MTI stg2R heads and not mill and they toll me that I can not run anything bigger than X1 cam cause off clearance I got some 2.05int and 1.60 exh
so it depends on ur valves how big are they
Old 12-30-2005, 09:52 AM
Xtnct00WS6's Avatar
I never understood that. Isn't the 2.05 a measurement of the diameter of the valve? If a bigger diameter valve inherently has a longer stem, then that makes sense to me, but why does the diameter of the valve play into PTV clearance?
Old 12-30-2005, 09:55 AM
cause the valve is at an angle, it makes it closer to the piston
Old 12-30-2005, 09:58 AM
i was bored, the red shows a larger valve, grey stock size valve.
pretty pic isnt it lol
Old 12-30-2005, 10:01 AM
Xtnct00WS6's Avatar
Now that makes sense...thanks!
Old 12-30-2005, 10:32 AM
SlickVert's Avatar
Impressive set-up!
That is similar to what I am looking to do.
I have a T-rex and looking for heads to go with it (kind of backwards I know).
I will fly cut the pistons and use a .040 head gasket to tighten up the quench.
Also, I already have fast 90/90 set-up
Car is running 11.3 to 11.4 cam only now, but looking to step it up a little while staying N/A 346
Old 12-30-2005, 11:14 AM
why dont you just throw a nice set of heads milled with that f13
Old 12-30-2005, 11:34 AM
SlickVert's Avatar
I agree, that is a good idea!
I started out wanting something a little more for the track to get into the 10’s cam only. Know while I have it apart I am rethinking my goals and maybe add the heads now.
As for the FM13 it is an awesome cam, both for the street and strip.
Just want a little more.
Old 12-30-2005, 01:07 PM
WsSickLs6's Avatar
you know, it's people like you that make the world a better place
you should get a job on sesame street
Old 12-31-2005, 12:18 AM
SVThis's Avatar
yep this is EXACTLY what i have been wondering...my buddy and i will be tackling the cam swap here in a few days or so and while we are in there we were thinkin about home porting the heads...i mean what can it hurt...has anyone actually P&P the stock LS1 heads with the T-Rex??
Old 01-01-2006, 09:32 PM
alans02z's Avatar
I was wondering the same thing.
Old 01-02-2006, 07:14 AM
SlickVert's Avatar
How do you like your T-rex cam?
Do you have any track comparisons?
Fireball is running some awesome times with a T-rex and heads.
Old 01-02-2006, 08:10 AM
alans02z's Avatar
I love my t-rex. Haven't been to the track with it yet though. Didn't have drag radials for about 2 months, then when I got them, it started raining and turn freakin winter here, and now I have to put poly mounts in it because the trans mount took a dump and so did one of the motor mounts. Should have done that when I did my cam, headers and clutch. Just didn't think about it. But its alot of fun on the street. Pulls real hard.
