Cracked block = junk???
Finally getting my LS6 block on the stand for strip down and notice a crack in the casting. This is on the back face of the block, the RH side lower rear headbolt casting boss. The tip of the boss is expanded outwards. I can spray fluid into the water jacket near this flaw and no leakage shows up, but spray down into the headbolt hole, and it definately leaks.
Is this block junk?? From initial inspection, I think it can be used, but looking for other opinions. Has anybody seen this happen before? If so, what was the solution?
Allan
Allan
That is usually caused by coolant or oil being in the hole when the bolt is torqued down, causing it to hydrolic craking the block. You would probably be fine running the block as is, but it won't cost much to get that welded for a peice of mind.
