tdc method...valve position
Old 12-31-2005, 12:21 PM
obZidian's Avatar
Default tdc method...valve position
Hey guys, real quick...
Im trying to replace just two broken springs and i would like to do this using the tdc method.
however, i was wondering if this can be done while cranking the motor over with the key and not the crank bolt? I dont have a big enough wrench....
Also, since i dont have my timing cover off, i wanted to know where or how can i verify tdc with the position of the valves. BAsically, at tdc, will both valves be down or up?
thanks, i appreciate this..would like to get this done as soon as possible....
Old 12-31-2005, 12:25 PM
2K2WS6TA's Avatar
@ tdc compression both valves will be closed (up)
Old 12-31-2005, 12:26 PM
obZidian's Avatar
so, basically i turn until both rockers are on the up position....
At this point, could i compress the spring so i can push down on the valve lightly and see how far it wil go down?...I just dont want to have a valve fall...that would SO suck right now!!!!!
Old 12-31-2005, 12:32 PM
2K2WS6TA's Avatar
Right, you can also (if you have a friend to bump the starter over, or a remote start switch) put your finger on the spark plug hole (after removing the plug) and feel for the air coming out
IIRC the piston @tdc will keep the valve from falling all the way in (not sure of that for an LS1)
You could use the rope trick, feed some rope into the cylinder thru the plug hole, and that will hold the valve up once the spring is off
ls1howto I believe has a post on how to change springs with the heads on
Old 12-31-2005, 12:33 PM
obZidian's Avatar
so i can turn the motor with the stater with the plugs out?
I know that sounds stupid but i just want to make sure...
Old 12-31-2005, 12:40 PM
bigdsz's Avatar
The best way to do it is to remove the spark plug or plugs where the broken springs are located. Stick a plastic soda straw in the spark plug hole. Preferably some can turn the crank bolt and you will feel the piston coming up, if you go past tdc just turn the bolt in the opposite direction. This method is fool proof, I've been doing it for 45 years.
Old 12-31-2005, 12:51 PM
2K2WS6TA's Avatar
Taking out the plugs should allow you to turn it by hand, or you can still use the starter.
The straw method is a good suggestion too
Old 12-31-2005, 01:11 PM
obZidian's Avatar
im gonna try the this out now, i'm gonna have to try it using the starter since i dont have a wrench big enough for the crank bolt.....
thanks guys.
update, good or bad, soon to be posted....
Old 12-31-2005, 01:15 PM
MadBill's Avatar
"Stage 3 Trans" in your sig sounds like an auto, but If it's a manual, you can also put it in gear and 'bump' the car forward or back to get it right at TDC...
Old 12-31-2005, 01:20 PM
Black Z/28's Avatar
I agree, rope, straw, small hose... these are very good methods. I used a small diameter rubber hose. When the piston reaches the top of the cylinder it clamps down on the hose until it feels tight when you tug on it. Low-tech and pretty fail-safe.
Old 12-31-2005, 01:26 PM
PREDATOR-Z's Avatar
Get a socket!!!
Do not crank with starter, it will never work.
Old 12-31-2005, 02:13 PM
obZidian's Avatar
well............
I got the plug of and used a straw to feel when in tdc. I cranked the motor over with the starter and with small cranks....it worked perfectly!!! ....
However....and im gonna try this without swearing my life away.....
I got the old, broken spring compressed with a compressor from an auto parts. Its the one with the handle. Locks like a crow-bar with a wedge/split end where the retainer goes.
Anyways, i got the spring compressed and removed the old spring and assembly. (sigh!) ....I installed the new spring assembly and when i was compressing to install the locks......
BLAM!!!!!!!!!!!!!!!!!!!!! The Fu...uh, freaking bolt broke off in the head!!!!!!!!!!!!!!!!!!!!!!!!!!! I used the yella terra bolt and that is gone!!!
AAAAAAAARRRRRRGGGGGGHHHHHHHHHHHH!!!!!!!!!!!!!!!!!! !!
Oh, did read that these are "notorious" for doing this but i figured that if i went slow that it would be ok....i didnt even crank it far enough to get the locks on....
DUDE!!! I flared!!!!!!!!!!!
Well, I guess my only solution right is to get the heads of and see if i can salvage them. If not, well, i guess this is a good time to inverst in a set of the new ET heads.
Im ao pisst'd.........my recomendation......NEVER USE THIS KIND OF SPRING COMPRESSOR!!!!!!!!!!!!!!!!!!!!!! EVER!!!!
.....OH, and thanks for the assistance, it helped alot just things like this just happened i guess....now to party as hard as i can so i can try and forget about this.
thanks again ppl!!
Old 12-31-2005, 02:18 PM
obZidian's Avatar
its an auto....SS3600 is the stall ratio from yank...thanks though!
Old 12-31-2005, 04:27 PM
Black Z/28's Avatar
Sorry to hear that man. After much research, I invested in the Crane spring removal tool and I have used it on 4 different spring removal jobs (it's slowly paying for itself). I know you probably don't want to hear this now but it's never a good idea to cheap out with the tools. Good luck with the head.
Old 12-31-2005, 05:25 PM
bigdsz's Avatar
For $30 you can get a Tim's Tool in the tool section of this forum. Works great.
Old 12-31-2005, 07:46 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Does that Tim's Tool have a good reputation?
Old 12-31-2005, 08:05 PM
bigdsz's Avatar
Go over to the tool section, I think there is about 5pages of posts.
Quick Reply: tdc method...valve position
