222/222 cam - suggestions please
Old 12-31-2005, 09:45 PM
50chevy's Avatar
Default 222/222 cam - suggestions please
will a 222/222 .566/.566 112 LSA cam work well in a modified 5.3? It will have new valve springs, headers, no emmissions, high flow MAF, and a retune. The engine will go in a small 3300# truck with a TH350 transmission (shift kit). How will this cam act (i want it to be streetable)? what kind of hp/tq can this make? lopey idle? Thanks everyone!
Old 12-31-2005, 10:58 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You will have some great mid range power that is for sure. You might have a little lope to it, but not too much. That is a really lightweight truck! you have a bed on thath thing?
Old 12-31-2005, 11:49 PM
50chevy's Avatar
i am going to replace the stock valve springs with ls6 ones, will these work fine with the cam lift and can i use stock push rods and lifters (59k miles)? are these springs direct replacements for my stock ones where i can use my same retainers and locks? any other modifications needed to make this cam work?
Orangeapeel, the truck is so light because it is a little 1950 chevy farm truck (rcsb) like the trucks at the Old Navy stores.
Thanks for replys! Any other suggested mods to this motor are welcomed!
Old 01-01-2006, 12:05 AM
gogogadget's Avatar
Lingenfelter sells a 222 cam for $250 that I have heard is for use with LS6 springs. Is that the cam you are looking at? $250 is a good price.
Old 01-01-2006, 12:17 AM
50chevy's Avatar
ya, that lingenfelter cam is the one i want to get!
Old 01-01-2006, 04:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
God, I used to work at Old Navy....
Old 01-01-2006, 11:06 AM
Ojustracing's Avatar
50 Check out my sig. My hp figures are low, but the torque is killer. Changed some things around just havent been back to the dyno. DO a search under my name I posted in the Dyno section. Later and Enjoy. John
Old 01-01-2006, 12:29 PM
BoneSS's Avatar
Before the overhaul, I made, through an unlocked 2800 Vig/LS6 intake/full boltons, 375/364 at the wheels using that cam on a 114.
Quick Reply: 222/222 cam - suggestions please
