Final check before ordering pushrods, Help!
Old 01-02-2006, 07:07 PM
MyGoatBites's Avatar
Default Final check before ordering pushrods, Help!
OK, I have everything I need for my heads/cam swap except the pushrods. Some of you guys gave advice on a previous post. Here is everything I know about my swap:
Cam Card
(What do you guys think of this cam for a daily driver, considering it's too late now anyways) Is 112 LSA and install at 108cl mean the cam has 4 degrees advance ground in?
I have Stage 2 241 Heads milled .010
Stock rockers
Factory Gaskets
Stock block
Trying to decide between 7.4, 7.375, or 7.35. I am going to be doing the install out of town, so it is important that I get teh right size because I won't be able to run to the hot rod shop for a set of pushrods. Length checker is out of the question for the same reason.
Old 01-02-2006, 07:22 PM
ChucksZ06's Avatar
I would go with the 7.375 but you should measure.
Old 01-02-2006, 07:25 PM
Is the comp cam base circle smaller than the stock cam? That is the one thing I am unclear about.
