tsp 231/237 & Comp Cam 231/237
what are the differences of these two cams? if any! I noticed tsp sells them but, it is a Comp Cam. just curiuos if any difference .
you guys running them what kind of rwhp are ya'll making? and on 1/4 mile runs wahat ya'll clocking or have clocked? on slicks or street tires? thanks guys
fuerzaws6
fuerzaws6
!LS1 11 Second Club
TSP 231/237 uses Lunati lobes, much less aggressive than the Comp XE-R lobes.
The Lunati lobes come on real hard at the upper mid/ high rev range, with some sacrifice to low end.
The Lunati lobes are very valvetrain friendly. You can use Comp 918's with them no problem.
Difference of the TSP 231/237 from .050 to .006 is 58/62 (intake/exhaust), far from the 49 range of XE-R, and more like XE (or even lazier still).
The Comp grind may exhibit more drivability and more low end while retaining the upper end at the expense of valvetrain stress.
just got my cam from comp cams. can somebody post or pm me tsp 231/237 cam card so I can compare it w/ Comp cam card I got w cam? want to see the difference.
thanks
furzaws6
thanks
furzaws6
Originally Posted by SouthFL.02.SS
thanks. this ealy helps.
fuerzaws6
