Southie's Setup Part II. Object: off the shelf 346ci max power. ETP 225, TRaK (LSK)
!LS1 11 Second Club
Given it much thought, I've decided to go all out out on a moderate 346ci. build-up using off the shelf stuff (instead of the low lift, sleepy lobe, budget head setup that I had spec'd before for this new project). This is my second project, this time, not on a daily driver, so what the hey.
Based on a few recent posts with feedback from Patrick G and others, along with the overall LSK discussion, I think I might as well join the LSK guys in exploring the high lift zone (which suits these heads very well).
SSRA (yeah, whatever)
TSP 85mm Lid
Pace 85mm MAF
NW 90mm TB
FAST 90mm LSX
ET Performance 225 heads, 62cc's using Comp921's.
Valve Lift Intake Exhaust
.100" 71 57
.200" 153 114
.300" 208 164
.400" 265 204
.500" 308 224
.550" 320 228
.600" 328 231
.650" 332 234
.700" 320 236
Thunder Racing TRaK 231/234 .640/.590 112 LSA
Edelbrock 1 3/4" to 1 7/8" Stepped LT's W/ slip on merge
Mufflex ORY-pipe (using 3.5" to 3" reducers at the header collectors)
Mufflex 4" Single tip Spintech (4" cutout in the I)
ASP UD Pulley
10 bolt w/ 3.73's (until it grenades)
Spec III
TSP 85mm Lid
Pace 85mm MAF
NW 90mm TB
FAST 90mm LSX
.100" 71 57
.200" 153 114
.300" 208 164
.400" 265 204
.500" 308 224
.550" 320 228
.600" 328 231
.650" 332 234
.700" 320 236
ASP UD Pulley
Spec III
!LS1 11 Second Club
BTW, sorry if these setup posts are annoying, but they're helping me hammer out what I really want to do before I go and spend a few thousand dollars.
LS1 Tech Administrator
You know this already, but don't forget to add that you'll be porting the FAST intake to match the ETP 225s. No need to knock down the excellent airflow of the heads with an unported intake. Also, you may decide later on to ditch the MAF and go speed density. The low speed driving manners are so much improved when you're not relying on a MAF being freaked out by reversion pulses.
If the heads are as good as they should be, you should be at or above 500 rwhp. I'm going to swap my 205s for AFR 225s (as soon as they ship) and hope to gain some more power. It will be a true A-B comparison. Same shortblock and bolt-ons. Just different heads.
You'll love your new setup Carlos. Post up after it's all built.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
!LS1 11 Second Club
^Will do!
Last time, I didn't port the 90mm LSX intake and it still did well, but this time, might as well do some port matching.
As for the SD tuning, that's something I've got to learn about now.
I'd like to see you break 500rwhp with those AFR 225's. That would be great news.
!LS1 11 Second Club
Originally Posted by krexken
Dream away! If this annoys anyone, they need not look at these posts! I like your new combo also. I also want enough power to scare me when I step on it.
Originally Posted by Sport Side
I'm actually more interested in what the dyno numbers will be than the track results!
(This won't be a 1/4 mile car anyhow).
!LS1 11 Second Club
Originally Posted by WsSickLs6
you sure do like starting threads don't you
But seriously, writing things out is helping me focus. The feedback is great also. I should have done this last time around, it would have saved me thousands.
Originally Posted by Rich
Damn, looks like I have some catching up to do!
Good luck with the new project Carlos!
I can't wait to see some more ETP results myself, so I say go for it. I do have a question. Why the exhaust set-up? Not saying its a bad idea or anything, just wondering your reason.
!LS1 11 Second Club
I want to retain a Y-pipe for 2 reasons:
1- clearance purposes. The curb cut to get into my driveway is steep and an X-pipe setup may scrape.
2- noise (I live in a noise restricted area)
If I'm going to be using a Y-pipe, might as well incorporate the proven 4" Flowmaster Scavenger Merge collector used in Mufflex/QTP Y-pipes. If I run a 4" Mufflex catback from that Y-pipe, I'll have 4" dia. exhaust running all the way out back, exiting out the rear of the car, never having been constricted down to 3" in any place after the left and right pulses are merged (the nice looking Edelbrock Y-pipe seems to provide a nice junction, but it does come down to one 3" pipe when it links to the I-pipe). The Spintech or Flowmaster mufflers used by the Mufflex catback aren't exactly the best flowing, so a 4" QTEC cutout in the I-pipe will allow me to see exactly how much power is being restricted at the muffler (if any), plus, I do like to run with an open cutout every once in a while.
Long winded explaination, but that's the story.
What do you think about using the Grand cup cam with 1.8 ratio rockers from the ls7 vette? That will pick up the lift from .570 to .604.
Do you really expect the valvetrain to hold up to the trak cam on the road course?
!LS1 11 Second Club
1st off, the car will see the occassional open track day and will not see an entire season's worth of track time. I think, just from my uneducated deduction, properly set up Comp 921's are up to the task for sustained periods of RPM, and perhaps some upgraded lifters may be in order. Do I think that it will hold up? We'll see. Being that this is not my daily driver, I can afford to experiment. At the end of the day, I may be all wrong about this, but I'd like to find out.
I think the Cup cam will require some valve reliefs. It also will give up lots of low and mid range response compared to the setup I have listed above (along with driveability).
Along your lines of thinking, a GMPP ASA cam with Vinci/Crane accel. lift 1.8 rockers would make a nice setup, bringing lift to .55X range (this would better suit a TEA stage 1 type head which makes good mid range numbers).
Yeah the grand cup cam requires valve reliefs. They say it makes good power from 4-7k.
If you have to buy new hydraulic lifters anyways, would a solid roller cost that much more? Solid roller lifters are lighter and can handle stiff springs without collapsing. Maybe thatd be a better way to go.
!LS1 11 Second Club
