rocker bearings breaking after trak cam install PLEASE HELP!!
Old 01-03-2006, 06:03 PM
THIRD-GEN92's Avatar
Default rocker bearings breaking after trak cam install PLEASE HELP!!
ok guys i just replaced my tr230 for a Trak cam specs are 232/235 644/592 112lsa, we installed patriot gold dual valve springs kit with the set up, everything looked fine and it turned on right away we left it on for a while and then truned it off to add coolant, the second time we turned it on i heard a clicking sound so i took off the vavle cover and i saw a broken bearing on the rocker on the intake side so i replace the rocker with another one from a extra set, i fired it up and again i heard the same clicking sound on the oppoiset side so again i took off the valve cover and saw another broken bearing on a intake rocker i figered something is wrong but i continued on replacing the rocker so i fireded it up one more time and the dam clicking was there again, it was another intake rocker with the same problem. i called thunder racing and they said i needed to install comp cams 921 spings only with the trak cam, i dont know what the diffence is on the springs, there both .650 max lift, can someone please help me figure this problem out.
Attached Thumbnails rocker bearings breaking after trak cam install PLEASE HELP!!-dsc02784.jpg
Old 01-03-2006, 06:27 PM
Dutchesscamaro's Avatar
It might be worth sending the stock rockers to Harland Sharpe, for ~$250 they replace the trunions (sic) and use clips to hold the assembly together. Well worth the $$.
Old 01-03-2006, 06:53 PM
vettenuts's Avatar
Did you fill the rocker body (where the bolt is) with oil? Wondering if lack of oil at startup and high spring loads are overloading/heating bearings. Not sure what heavier springs are going to do, especially if they failed at idle which you have indicated. Something is wrong and you need to figure out the problem.
Old 01-03-2006, 07:09 PM
redtail2426's Avatar
how is your piston/valve clearance,just a thought.
Old 01-03-2006, 07:20 PM
seems to be that all my rocker bearings on the intake side are broken, exhuast ones are ok. could this be coil bind? woundering cause lift on the intake is .644
Old 01-03-2006, 07:22 PM
Restricted User
CAT3's Avatar
Very well could be and would make sense.
Old 01-03-2006, 07:28 PM
before i purchased the cam i asked thunder racing if piston to valve clearance was an issue on a stock ls1 motor. they said that if my heads were never removed, which there arent, that there shouldent be a problem and that there should be more than enough clearance.
Old 01-03-2006, 07:59 PM
vettenuts's Avatar
Coil bind is logical, the binding would really load the bearings in the rocker, and the lifters too. Did you roll it over by hand? The retainer may also be hitting the seal.
Old 01-03-2006, 08:16 PM
i did'nt roll it over by hand but i think thats what im gonna do right now, i think there binding alot and the rocker is getting kick off to the side alittle, and are twisting the bearings off imo
Old 01-03-2006, 08:58 PM
aux_fast_cam's Avatar
I think that cam is going to require an exotic valve train setup to be right. I think I would reconsider cam if it were mine.
Old 01-03-2006, 09:27 PM
you think so, now im confused.... na i think i just missed out on some ajustments somewhere, still trying to figure it out
Old 01-03-2006, 09:58 PM
SPEEDYws6's Avatar
Since it's only happening on the intake side make me think it is a spring issue. Like said above, either coil bind or the retainer is coming in contact with the seal which should be really easy to tell. I don't think you should change cams, just get the recomended springs. I think you will find that that is where your problem is.
Old 01-03-2006, 10:44 PM
thunder racing recomendes 921's, but i am using patriot dual's, is there a differance in there design?
Old 01-03-2006, 11:06 PM
LS1 Tech Administrator
Patrick G's Avatar
Comp 921s are designed to handle more lift plus they have greater pressure. That's what I'm running with my TRak cam. Stock rockers and stock lifters. No problems at all.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-04-2006, 02:44 AM
DaddySS's Avatar
I would say coil bind, why not call Thunder and ask them the question?
Old 01-04-2006, 06:58 AM
vettenuts's Avatar
Coil bind on the 921 is 1.04 and on the Golds is 1.09 according to my information. Do you have the Golds heavily shimmed? What is the installed height?
Old 01-04-2006, 12:18 PM
Gunnar@Patriot's Avatar
Did you use the spring bases and seals that came with the spring kit?
Old 01-04-2006, 11:48 PM
I gave a call to you guys at patriot first thing in the morning, after i told them what was happening, that was the frist thing they asked me, no i did not use the bases and seals , and they said theres your problem, so i finally swaped them out and now it's working great. i let idel for a while then i took it out for a spin, the thing runs like a champ. Ill be out geting it tuned tomorrow ill keep you all posted on the results thanks guys.
Old 01-05-2006, 12:02 AM
slowredz's Avatar
That a bullshit response from Thunder, they should be more helpful than that and ask some more ???s about your setup and not just recommend you spend another $500+ on something you dont need. that makes me never want to deal with them
Old 01-05-2006, 01:05 AM
FUN LS1's Avatar
It might seem that way at first, but do you really expect TR guys to know what comes in the Patriot Gold kit, and what might have been left out of their install process? Who elses springs should TR guys know how to troubleshoot? See what I mean?
