head gasket removal?
Old 01-04-2006, 01:51 PM
scarbrow's Avatar
Default head gasket removal?
i just pulled my heads on my camaro, and when you are removing the old gasket, and there are little flakes of it going everywhere do you just not worry about it getting in the coolant ports around the cylinders? or is there any way to keep it out of these since they are really not big enough to get a rag in? i was just wondering if most people just don't worry about it and then just do a coolant flush once it is back togeter?
Old 01-04-2006, 02:29 PM
GregWS6&z28's Avatar
use a paper towel, (cause you need to anyway to soak up coolant out of the head bolt holes). Just roll it up tight enough you can push it down into the holes. just make sure you get all the coolant out. when I did my heads I did a coolant flush just to make sure
Old 01-04-2006, 02:55 PM
radkon's Avatar
Plug the coolant holes with paper towels (in strips if you need just don't push them all the way down)
Also if you have to scrape any gasket residue don't use a metal scraper. Use a plastic one, you can easily gouge the block or heads. If it's real stuborn use gasket remover (chemical) to lossen it up first.
Old 01-04-2006, 03:18 PM
gasket remover should be a must-have when cleaning up. makes the job 100x easier than it could be
Old 01-04-2006, 05:24 PM
SgtB's Avatar
blow out the head bolt holes with air and that should get everything out
Old 01-04-2006, 06:30 PM
oange ss's Avatar
shop vac
Old 01-04-2006, 06:48 PM
WideOpenThrottle's Avatar
What he said!!!
A buddy of mine with little effort broke a head bolt cause there was some water still in there. Took 3 hours to get it out.
Old 01-04-2006, 07:02 PM
Dipstick's Avatar
I used paper towels in the bolt holes and water passages. Kept tearing off the wet part until the bolt holes were dry.
For the gasket, I used a Roloc abrasive disk with all the tiny fingers in a medium grade.
Old 01-04-2006, 11:34 PM
SgtB's Avatar
Originally Posted by WideOpenThrottle
What he said!!!
its deinatley the fastest and easiest way to get the holes clean and then I would suggest chasing the threads for added comfort
Old 01-04-2006, 11:55 PM
PREDATOR-Z's Avatar
Shop Vac
Old 01-05-2006, 01:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Shop vac or a nice nozzle on the air compressor will work.
Old 01-05-2006, 09:38 AM
SgtB's Avatar
these two are your best options
Old 01-05-2006, 12:35 PM
LS1-450's Avatar
I am in the process of doing exactly what you are. Kept thinking " what the hell am I goin to do about these tiny gasket flakes?" Got tired of trying to keep them out of things & let 'em go. They came out of the bolt holes when I paper toweled the holes for drying & I used a tiny tube connected to a shop vac to suck out the bolt holes & coolant passages. Am planning another flush after everything is put back together.
Might want to check your intake to head port alignment. Measured the distance from the first bolt hole to all the runner openings on the intake & compared the same dimensions on the heads & found that the intake runners on the passengers side head were missaligned by up to an 1/8" on the width & 1/8" on the length (on the bottom, opposite side from the fuel injectors). Did what I could to help better align the ports by grinding chamfers on the head to make air flow a bit easier. Also found part of the intake gasket to be overlapping the runner opening in a couple of places.
Old 01-05-2006, 09:29 PM
SELLSZ06's Avatar
use a straw taped to the end of the nozzle, that will get deep in there and then use paper towels, then get use a grinded down old head bolt to get all the junks out of the holes. check out ls1howto.com.
Old 01-06-2006, 05:48 AM
Teutonic Speedracer's Avatar
Similarly, I used the Roloc also, jus the lightest one (white I think)
