Post up your ultimate/dream setup!
Old 01-08-2006, 12:18 PM
8banger's Avatar
Default Post up your ultimate/dream setup!
Hey everyone, I've been daydreaming and watching way too many ls1tech/streetfire videos, and thinking of what I'd do if I had money. Here's my dream set up:
-370ci aluminum block (LS2, iron-sleeved, bored .030" over)
-Forged rods and pistons
-Paxton Novi 2000, 12psi (would take some custom work)
-Custom blower cam (somewhere in the high 230's/low 240's)
-ET 225cc heads
-Port-match FAST 90 intake/NW 90mm throttle body
-FAST direct port nitrous setup
-QTP headers with HVMC's
-QTP ORY
-Custom dumped Corsa catback
-Built TH350 with Gear Vendors overdrive (6 gears!)
-3800 stall
-12-bolt with 3.90's
Old 01-08-2006, 12:58 PM
gccasper04's Avatar
mines not that big but:
LS6 block
F13 cam
LS6 heads with "the works"
fast 90/90 setup
MAF nitrous kit with a 75/100 shot
built 4L60E, 3500 stall
12 bolt with 3.73's
and full suspension
hopefully I can pull some mid 10s with that setup if not faster
Old 01-08-2006, 01:04 PM
slow trap's Avatar
500ci ls1, 101-106 mm thumper turbo, 160 lb injectors,lenco,all in a street car.anybody want to race from a roll ???
Old 01-08-2006, 01:07 PM
8banger's Avatar
Ha...hell no. Well, you'd beat me for a little bit until you ran out of gas,...then we'll see. Haha...
Old 01-08-2006, 01:16 PM
Wnts2Go10O's Avatar
402 TT aluminum block and whatever 15psi will get me. or v2: the first to build a pro-mod lsx motor with a world block, 6 bolt ls7 heads, custom intake, and a HUGE twin turbo setup or the biggest centrifugal blower i can find. hey slow trap, race ya froma dig
Old 01-08-2006, 01:30 PM
8banger's Avatar
Ok, now I'm thinking too much. I was thinking of what my ultimate N/A and N2O setup would be for what I want and here's what I came up with:
-370 aluminum block (LS2 bored .030" over -- see a pattern here?)
-Forged 3.622" crank
-Forged rods/4.03" domed pistons
-Custom ground cam (252/260, .610"/.620", 115LSA)
-P&P milled LS6 heads (target compression ratio = 11.5-12:1)
-Port matched FAST 90mm intake
-FAST 90mm direct port nitrous system
-Edelbrock Victor Drag stepped long tube headers
-3" ORX pipe to dumped Borla XR1's
-Built 4L60E
-3800 stall
-Built 10-bolt with 3.42:1's
Highway car. Would be fun.
Old 01-08-2006, 01:47 PM
Bearcat Steve's Avatar
DREAM scenario.................
1) Jessisa Simpson ditches Nick (so far, so good).
2) She meets another Bearcat fan (could happen).
3) She falls in love with said Bearcat fan (OK, its a BIG stretch).
4) She marries said Bearcat fan and for a wedding present she gives her new hubby $1,000,000 for his car and his weekend hobby of racing (also a BIG stretch).
5) On their wedding night........................... (OK, it AIN'T gonna happen).
Old 01-08-2006, 02:03 PM
Elite_Hot_Rod's Avatar
A Lenco for street use? LMAO
Old 01-08-2006, 02:07 PM
Wnts2Go10O's Avatar
with money, anything is possible..
Old 01-08-2006, 02:08 PM
Biggest CID available
Solid roller
Dart block
Lunati crank
ET heads
Sheetmetal intake
106MM turbo
Assembled by Rehr-Morrison
Then I woke up, lol.
Old 01-08-2006, 02:35 PM
ronan's Avatar
dream setup would be an ihra prostock setup. but for a gen III it would be what i'm building right now
6.0 0.030" over
callies racelight 4.125" crank
grp rods
wiseco custom 11* pistons
etp 255cc 11* heads
huge solid roller
beck sheet metal manifold
jesel lifters
LSM springs and valve train
t&d rockers
libertys gears tranny, ram clutch, mcleod prostock can with adapter for ls1 bolts
2900# race weight
91mm single front mount a2w and a plate for fun...should be done as soon as the damn pistons get built
Old 01-08-2006, 03:05 PM
350-Z28's Avatar
Well here goes:
383 c.i. unless i can get bigger LS1 aluminum block
Forged 4 inch stroker crank (or more havent decided)
100-120 lb/hr injectors
Aftermarket heads (havent researched yet)
Lingenfelter intake manifold w/90mm throttle body
Custom headers meeting up with two turbos
Obviously the turbos (something by garret, looking into T4's)
Fidanza (SP?) flywheel
Carbon fiber driveshaft
Built T56 trans
4-link suspension w/quick change rear end
6-8 pt roll cage
intercooler for turbos with nitrous cooling
underdrive pulleys
fairly agressive cam (again no research as of yet)
as many fibeglass panels as is possible on my application
lifters and springs
roller rockers
That should cover it, haven't researched too much because I'm only stripping the engine and car and will do body mods first then go to all engine and trans mods. Will be building this set up, just a matter of time.
Old 01-08-2006, 03:45 PM
11 Bravo's Avatar
Warhawk LS7X 4.125 block
Lunati rotating assembley 4.250 stroke
biggest SR cam that will still idle
ETP 225 11 degree heads (maybe, still ain't seen results yet)
Jesel rockers
Morel solid lifters
Direct port 300 shot
Old 01-08-2006, 04:07 PM
Wnts2Go10O's Avatar
Jesel rockers
Morel solid lifters
wntingto go 6's or somethin?...l
Old 01-08-2006, 04:11 PM
Hennytime's Avatar
i was thinking simililar things. LS7 with full boltons and full valvtrain package from LGM with a direct port jetted for 250rwhp
Old 01-08-2006, 04:33 PM
11 Bravo's Avatar
Naw, just want to rape everything I come across on the highway
Old 01-08-2006, 06:09 PM
Ferocity02's Avatar
TT 427 C5R
Old 01-08-2006, 06:41 PM
Wnts2Go10O's Avatar
raping is an understatement
Old 01-08-2006, 06:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
enzo....
Old 01-08-2006, 07:08 PM
CHRISPY's Avatar
Warhawk block and heads, custom intake (402 ci) with 8.0:1 compression
custom turbo setup with twin MP T70s
Relatively mild cam
BS3(Big stuff three)
Massive air to air intercooler
Monster fuel system (160# injectors, dual 420L pumps, custom return and regulator)
17#'s boost on pump gas
Comfortable 900 RWHP
