what rpm to shift at with Futural f4 226/226 .575/.575
I just finished a cam install this weekend and i was quite pleased with the install. I put in hardened pushrods, ls2 timing chain, ls6 oil pump, 921 spring kit with titanium retainers, and the cam i listed above. It says on futurals website the range is up to 6600....rite now i still have the stock rev. limiter but where should i set the new one? And where should i shift i was thinking 6200 maybe 6300
Originally Posted by PREDATOR-Z
Get it tuned on a dyno. Set limiter to 7000.
From the graph you get then decide on shift points and reset limiter 300 above those sift points.
I had a similar cam (226/228 569/588 112cl) in my old car. I shifted @ 6,400-6,500 and the limiter was on 6,700
