what does a stock ls1 head flow?
This is from Chevy High Performance's online cylinder head flow database.
Production LS1 Aluminum Head
GM won’t be left out of category 3 with these heads. This head has great 0.400-inch lift numbers as well as a good E/I ratio. They also feature a more flat valve angle (15 degrees) in order to promote a better combustion chamber that’s shaped like a kidney to help direct combustion and reduce possible detonation. Remember that this head will not interchange with pre-‘93 small-block heads.
Jason
Jason
