MS3 & Patriot Stage II LS6 Heads Flycutting??
Does anyone have any experience with this setup? I have a buddy that has just bought this setup and would like to know if flycutting will be necessary before we start the install.
Measure PTV and if very close, you can always run a slightly thicker gasket.
Not all motors are created equal, some have been seen from .005>.010 out of hole.
So get a dial and measure.
Also changing advance will create clearance, ie retarding your cam. Many options here, before molesting your pistons.
LS1Tech Premium Sponsor
Those heads will definately not clear with the magic stick camshaft. You'll have to cut the pistons to get the larger valves to fit
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
why would a stock deck lq9 head with same size valves not clear?
I was thinking about that for the last two days with out finding the answer. but any way keep the cam only mod and when you are ready just sale it and get a mid cam with nice set of AFR or TEA or ET or PP with out the headache of knowing your gain and you cant go wrong with any one of them .for Gunnar I would like to say thank you for every thing man
Our LS6 style heads will be at the approximate factory deck height. When compared to heads with the same valve sizes, this will allow for more PTV clearance over heads that have been milled below deck height. This is one of the great advantages to using our LS6 style heads. Plus you can custom order your chamber sizes and heads are built with the highest quality components.
Nothing Funny about this Full-Force, I build the PRC MS3 friendly heads specific with the valves setup so it clears. With extra time working on the heads & playing with the short turn you can get the cylinder heads to still flow well with valves sunk for better p/v....
I have several camshafts just a little smaller than the Magic Stick that will clear with Gunnar's head.
Originally Posted by Full-Force
thats funny because you just sold that same cam to a customer with a prc 5.3 head with same size valves and customer was told it would clear
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Retired Street Racer
I have the MS3 and Jason is gonna do a set of Dart 225cc heads with 2.065/1.60 Manley valves. I will not have to flycut the pistons. Gunnar is a great guy and has helped me in the past, but if you have a TSP cam that may have an issue with clearance, I would talk to TSP since they know what works with their cams and what doesn't.
I save the gassle and just buy the ETP's.
Forget the darts, the ET head will make more power and you damn sure wont have to worry about P/V then.
