Valve spring seat question- picture
F11 Cam, Valve spring seat question- picture
I have a Futral F11 cam. This is one of the valve spring seats and shims that came with my Manley dual springs from Futral. Does anyone know what the purpose is of the shim on the right? Why is it necessary?
you have to check the available spring height on the head to determine that. for instance, if the spring requires an installed height of 1.800" and you measure 1.830 from seat pocket on the head to the bottom of the retainer, then you'll need a .030" shim to make up the difference.
top/bottom doesn't matter.
