H.p.e???
Old 01-11-2006, 03:57 PM
BOTTLEFEDLS1Z's Avatar
Default H.p.e???
Is anybody running their "S" cam with their stage 3 5.3 heads? I would like some comments on their products. Thinking about going with that setup of the "s" cam and heads.. Thanks
Old 01-11-2006, 04:15 PM
TAQuickness's Avatar
Give Chuck a call (281 448 1300). I'm sure he has some dyno graphs of that combo he can share with you.
They are a nop-notch outfit and will work with you anyway they can to make sure you get what you want.
Old 01-11-2006, 04:23 PM
So, I assume that you've dealt with them?
Old 01-11-2006, 04:28 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
HPE will do you right!
That combo should have no problems, but Chuck should be able to provide more details and results.
Good luck!!!!
Old 01-11-2006, 04:32 PM
MrBill97396's Avatar
I will tell you from first hand expierence the combo is great. There salesman Scooter is running it on his 99 SS and when he had a 6 speed in the car he put down 465 hp with kooks headers and y-pipe. With the 6 spd. on the highway I believe he had 3.42 gears he was getting 24 MPG. I was his roommate for 3 years so I know first hand what the package does on the street and the strip. Give him a call 281-448-1300 they are a good bunch of guys and will answer all your questions. Good Luck !!!
Old 01-12-2006, 01:56 PM
Thanks guys for the replys!! I talked to Scooter and it seems like its a pretty stout package. Incredible flow numbers out of those heads at .600 and .650..
