View Poll Results: Should i change oil pump with cam swap?
Yes change it
79.63%
Just doit when you get back
20.37%
Voters: 54. You may not vote on this poll
Change oil pump with cam swap? poll
Old 01-14-2006, 02:28 PM
ws6sojuiced01's Avatar
Default Change oil pump with cam swap? poll
Should i change the pump i only drive the car 3000 miles a year(and the wife drives most of that) do to being in the military 4000 miles away from the car.at least for the next 4 years.
Old 01-14-2006, 02:35 PM
Ferocity02's Avatar
Might as well as long as you're in there. How many miles are on it?
Old 01-14-2006, 02:39 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Yes you should.
Old 01-14-2006, 02:50 PM
ronan's Avatar
that's up to you, i've done 20 or so cam swaps and never had any oil pressure problems at all. ported oil pumps on stock cars are just extra insurance and not something 100% nessecary at all.
Old 01-14-2006, 03:23 PM
CRL 01 SS's Avatar
I like having the extra insurance and piece of mind. Went with a TSP ported LS6 pump when I had my MS3 installed.
Old 01-14-2006, 06:00 PM
Bigrob339's Avatar
Go with a Katech ported pump, thats what is on my car!!
rob
Old 01-14-2006, 06:06 PM
LS1TECH Sponsor
Katech_Jason's Avatar
Old 01-14-2006, 06:58 PM
WsSickLs6's Avatar
that 100$ could save you thousands down the road...i vote yes
BigBlockChev572's Avatar
I didn't change mine. I have 67K on it. My oil pressure is 55PSI cold. I don't believe in the "ported" oil pump hype.
Old 01-15-2006, 12:14 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I would do it. Never hurts to have fresh parts when adding power.
Old 01-17-2006, 01:31 PM
DONAIMIAN's Avatar
Depends, if it was a 00 and earlier, then it would be higher on my list to replace. I think the 01+ cars came with the LS6 pump and if thats the case, then I wouldnt mess with it unless your changing out the timing chain.
Old 01-17-2006, 04:00 PM
blkZ28spt's Avatar
I wouldn't do a cam swap on a 97-00 LS1 without also swapping pumps, but on a lower mileage 01+ it's really not necessary.
Old 01-17-2006, 04:04 PM
so i have an ls6 pump in mine i have a 01?
Old 01-17-2006, 04:12 PM
blkZ28spt's Avatar
Yes. Which means you shouldn't have to worry about it taking a crap on you.
Old 01-17-2006, 10:04 PM
P Mack's Avatar
I wouldn't do it, if you did you'd have to mess with the pickup tube, o-ring, etc. You already have a pump you know is good.
Old 01-18-2006, 12:45 AM
1badA3Z's Avatar
i wouldnt mess with it either,not many miles on it and newer model car,i think it will be ok,jmo tho
Old 01-18-2006, 03:49 PM
fasteddyss's Avatar
I did it with my cam swap. My oil pressure went up so I figure it was worth it.
Good Luck
Old 01-18-2006, 08:23 PM
2scoot's Avatar
Smooth out the casting flaws yourself and save the $$. Also a good rule of thumb is 10 psi for every 100 HP.
Old 01-18-2006, 10:21 PM
Dan_the_C5_Man's Avatar
LS1 and "LS6" oil pumps are the same. If you've ever disassembled one you'd know this. The problem area is casting flash / other junk getting caught in the pressure relief valve. So disassembling and cleaning your stock pump is just as good (or better) than buying a new one. You can also add a small shim under the spring to bump the pressure if desired.
