Ls1 Cam change now Smoking !!!
Old 01-14-2006, 05:06 PM
69c4x11's Avatar
Default Ls1 Cam change now Smoking ????
Just changed from a 570 lift to a 598/595 lift ... Now engine is smoking like a Tar kiln ??? How much lift can you go on stock valve seals ?? Had to remove baffle for Comp adjustable rockers,, I 've pulled PCV out and let run for approx,1hr still smocking,, it probably turned 6k on the try-out then was smokin,,,, didn't smoke till I carried it on the shake down??? Any Info !!!
Old 01-14-2006, 05:14 PM
MiaSSmaro98's Avatar
have u ever replace ur vavle seals?how many miles on the motor?or ur vavle guides are worn out but this is usually on high mile engine
Old 01-14-2006, 05:20 PM
69c4x11's Avatar
Seals have never been replaced only 7k on 6.0l Escalade engine,, No problem till I changed cam, carried on shake down and turned 6k,, idled in shop for probably 1hr no smoke till driven ???
Old 01-14-2006, 11:03 PM
dudas35's Avatar
Lift should have nothing to do with valve seals. I ran .588 lift on stock seals up to 6600 rpms and had no issues and i've seen higher. You sure you didn't puncture one when you replaced the rockers, even then it shouldn't smoke as bad as you are saying.
Old 01-14-2006, 11:04 PM
69c4x11's Avatar
ttt,,,,, bump
Old 01-14-2006, 11:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Yikes! You change the oil yet?
Old 01-15-2006, 08:48 AM
69c4x11's Avatar
Yes,, it has been changed before cam - rocker arm change,,as i said no hint of smoke before until driven,,
Old 01-15-2006, 08:51 AM
69c4x11's Avatar
You mean you have to change oil ???? D---- guess thats it !!!
Old 01-15-2006, 10:54 AM
ArcticZ28's Avatar
Any ticking in the valvetrain? I'd pull the valve covers and rockers and check the valve seals. It's simple and would eliminate a lot of guessing here. It could just be coincidence that something happened after this cam swap. Where is it smoking from? Could it just be that oil is leaking down onto the engine somewhere?
Old 01-15-2006, 12:07 PM
69c4x11's Avatar
It's smoking out exhaust, has X pipe ,both sides,, I've pulled pcv valve out and let idle in shop to see if it would clear up,, still didn't,, WISH I hadn't pulled the Comp cam out now,, and left stock rocker arms on...
Old 01-15-2006, 12:12 PM
ArcticZ28's Avatar
Pull the VC's and check the valve seals. That's the easy elimination at this point. If everything looks fine in the valvetrain you could have hurt something in the piston/ring area by spinning to 6k. Did you spin that high with or without tuning?
Old 01-15-2006, 02:52 PM
69c4x11's Avatar
Spun with out tuning,,, had a 570 -226 114lsa in it was fine..
Old 01-15-2006, 03:50 PM
dudas35's Avatar
What kind of valve springs are you using?
Old 01-15-2006, 05:29 PM
69c4x11's Avatar
Comp 918's
Old 01-15-2006, 06:02 PM
glennhl's Avatar
What valve tool did you use to change out the springs? I had a tool that I used that rotated so far that it was hitting the valve stems and leaving marks. I measured the marks and they were just high enough not to go through the seal. However, with more lift I probably would have had the marks go through the seal which would have ruined them.
Old 01-15-2006, 06:32 PM
69c4x11's Avatar
Springs were installed when the first cam change from stock,, approx, 1k miles ago,,,,,
Old 01-15-2006, 07:25 PM
P Mack's Avatar
Probably shouldn't matter with stock heads, but did you use thread sealer on your rocker arm bolts/studs? I've heard you can suck oil in through the rocker arm threads if the rocker bolt hole extends into the intake port.
Old 01-15-2006, 07:32 PM
69c4x11's Avatar
Yes I used Loctite on the threads,,,, This is just my luck !!! It is the second cam change for engine with less than 7k miles,, Just wanting a different sound... Now the troubles begin !!!!
Old 01-15-2006, 07:55 PM
ArcticZ28's Avatar
Welcome to the game
Old 01-15-2006, 08:04 PM
rck329's Avatar
Retainers hitting the valve seals?
