How good are these flow #'s???
Old 01-15-2006, 11:10 AM
98SuperSport's Avatar
Default How good are these flow #'s???
Here they are - 2.00 intake and 560 exhaust
.INTAKE CFM
.100 71
.200 138
.300 194
.400 231
.450 244
.500 271
.550 358
.600 294
EXHAUST
100 .63
.200 . 102
.300 . 129
.400 . 151
.450 .174
.500 . 181
.550 .190
600 .200
Want to know how good these heads would be. They are ported LS1 heads BTW. Thanks for your help
Old 01-15-2006, 11:24 AM
SAM98WS6's Avatar
not real good...weak on the exhaust side
Old 01-15-2006, 02:35 PM
Bo White's Avatar
Is the exhaust w/o a pipe? If so then its not real bad, the 358@.550 is a typo on the intake? Should be since its an ls1 casting through a 2" valve.
Old 01-15-2006, 07:33 PM
i dont know i'm buying these heads for my car the guy who had them first said that he made 60rwhp in his car with an auto and hotcam (he had all supporting mods too)
what kinda power will they make with a big cam?
Old 01-15-2006, 09:45 PM
DavidNJ's Avatar
There is something really off if it lost 15% of its flow on the intake from .550 to .600.
This thread may provide some insights: https://ls1tech.com/forums/advanced-engineering-tech/436695-importance-high-lift-flow-vs-mid-lift-flow-power.html
I wouldn't spend the time or money (for gaskets, etc.) to install them.
Old 01-15-2006, 11:01 PM
Bo White's Avatar
Depending on how and what flow bench was used the flow #s just dont look right up top with the high and low- the high being too high and low being well....to low of a drop. LS1 heads flatten out up top but this is odd. If they made 60 additional rwhp over not havin them then thats OK and would more than likely make more power with a larger cam- as do stock headed LS1s. The choice is yours to make in the end, just looks wierd to me. If you have an opportunity have them reflowed by somewere else and see.
Old 01-16-2006, 11:17 AM
110 views and 5 posts??? any help is greatly appreciated
Old 01-16-2006, 11:48 PM
how much power over stock do you think they would make?
Old 01-17-2006, 07:07 AM
SAM98WS6's Avatar
dude...you get what you pay for...why take the chance...
Old 01-17-2006, 10:45 AM
Gunnar@Patriot's Avatar
Don't know how much the asking price in on these, but if you are looking for the best deal on a set of heads, look no further.
We can do you a set of our 243 castings that are CNC ported with 2.00"/1.55" valves, LS6 springs, new GM MLS head gaskets and new OEM head bolts for only $865.00 per pair assembled. This is an excellent value on a quality set of heads. Here are some flow numbers on these:
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
These numbers are taken on our Superflow 1020 bench using a 3.905" bore and a clay radius. We offer a few different options on these 243 castings. For a complete listing, take a look at this thread:
https://ls1tech.com/forums/generation-iii-internal-engine/435820-cnc-ported-243-budget-heads-865-00-per-pair-assembled.html
Old 01-17-2006, 04:26 PM
the seller made 60whp with them and a hotcam....is it cuz the hotcam is smaller and works better with these heads? i dont want to get them and when i go to throw in a bigger cam like a F14 the car is a turd
