NEED CAM HELP ASAP!!! ordering today!
ok... i have decided i am going to go bigger with my cam than i originally decided ... HOW BIG CAN I GO ON MY 408??? i want something lopey as hell but still streetable. my pistons are flycut, HPE 408 zero decked...
the car is a daily driver.. it WILL be running NITROUS.. probably quite a bit. but i will only be spraying nitrous on rare occasions.. for the most part it will be NA but the juice will be sprayed if i need it. (or when im at the track) i need cam opinions REALLY FAST!! the engine is starting to go together and im without a cam and i NEED ONE!! lol
any help is MUCH appreciated!
compression is 11.4:1... i just got off the phone with paul at thunder racing.. he suggested a custom grind aroudn 248/252 6xx/6xx on a 113 + 4 LSA.. i think ill stick with that
Have you talked to HPE about a cam? I am probably swapping in their S-cam which is a 238/242 .608/.612 lift on 115 lsa this spring. I talked to Scooter at HPE he claimed he put down 467 rwhp w/ ET heads.
249.6 / 254.9 613/619 on a 111.1 LSA its a bit motha trucka... they put down 680 RWHP on a 150 shot in their 408 built the same as mine.
