Questions from a newbie
Hey guys, I have a couple of questions about my 98 Z28 A4. When shifting from 1st to second, its pretty hard, and if I am getting on it a bit, it spins the tires: at first I thought it was form the traction control system, but I turned that off and it still does the same thing and it doesn't shift like that every time either. Would this be a problem with the tranny or is it normal? Also, when I am shifting out of park to any gear, it sometimes takes 2-4 seconds before the transmission goes into gear. I don't know if this is normal, since this is my first F-body and all the other guys I know have M6's and any other automatic I've owned (RWD) has never had much of a delay like that. Normal driving is smooth with good clean shifts. any input would be appreciated!
That doesnt sound right. I was having minor proplems with my old LT1 Trans at 120000 mi
It felt weird when shifting normal and slipped ever so slightly. I changed the fluid to Royal Purple and changed the fillter and it stopped all the slight slipping and it shifted better.
I am having the same problem with my 1st to 2nd gear. I thought it was normal?
But my buddys b4c kinda has the same problem? Or do we have 2 bad transmissions?
