Tsp 231/231
!LS1 11 Second Club
Tsp 231/231
Remember that cam? It was dropped from their website some time ago.
I bet it would make for a fine roadracing cam.
Lunati lobes, not too aggressive (.006-.050=58 I think, assuming the 231 is the same as the one used on the intake of the 231/237), should be good for sustained high revs and should be valvetrain firendly. Single pattern for better tq than the large split of the 231/237. Just enough duration for great power. Good lift.
Wasn't it 231/231 .598/.598 112?
Anyhow, I called TSP today and they said it's still available, as well as any Lunati grind they/I/we can come up with is available.
Just a thought.
Just a thought.
!LS1 11 Second Club
Originally Posted by -Joseph-
Comp lobes consistantly made more power. I liked the 231/237 when it was popular, now I think my favorite is the 232/234.
LSxGuy widda 9sec Mustang
I think my concerns for high engine speeds would be more along the lines of stock lifters and rocker arms. While I don't like the aluminum rockers that have a lot of weight over the valve, there are a few steel rocker arms out that seem to minimize that weight. On the lifters, I just don't trust them for anything other than mild builds or stock cams. Seen too many die from just a stiffer spring swap.
A good spring and lightweight ti retainer can handle the XER lobes just fine though. I've used 918 springs in some crazy stuff before and they always held up fine (mine have almost 60K miles with .610" lift) . The double springs have been doing very well, and have proved themselves numerous times also.
!LS1 11 Second Club
Originally Posted by stang killer
Youve really been disceting different set ups on combinations latley, lol.
As soons as I'm back at work, I'll actually have the funds to put together one of these setup combos.
!LS1 11 Second Club
Originally Posted by 2000blackta
I am still running this cam. I haven't had it to the track yet but I am hoping that it will work well with the AFR small bore 225's that I have on order.
Originally Posted by SuperZ
I used to have the 235/240 603/600 112+2.It was a presision grind.It worked really well and did good with nitrous.I think they only made about 20 of them.
The heads should be here by the end of the week, I'll be sure to post track and dyno #'s.
I'll be looking forward to your results. I very interested to see how much more AFR's can produce compared to my Patriots.
