piston slap
Piston slap can be annoying.
The loose clearances that cause cold piston slap also protect the cylinder walls from being scored during high stress/demand applications, particularly under boost.
It is common to see a 150k LS1 motor with piston slap to have like new cylinder bores with cross-hatch still very visible.
That's all you need to know about piston slap.
next please...
Jason
next please...
Jason
Originally Posted by Benjamin Russick
It's all a bunch of BS anyway. Piston slap is a non-issue and hardly GM-specific...
Originally Posted by stangnightmare
i've got a '00 Z28 with 60,000 miles that seems to have "piston slap" problem. is there anything you can do with it(not to steal your thread) or do you just live with it?
What kind of oil are you running? My car has always had piston slap. Last year I decided to switch oils (went from M1 10w30 to M1 0w40) and my piston slap got really bad. Then my oil consumption went to hell. Switched back to 10w30 and the car went back to the way it was before. If you're running a 0w or a 5w...try going up to a 10w and see if it helps out.
I've been using 10w the whole time, so i know that's not going to help. i think i'm just going to do a piston swap. i can't live with this piston slap. i think it will pay off in the end anyway.
we'll i'm glad to know i'm not the only one with this problem. this is my first gm V8 so i had no idea about "piston slap." now i can breathe a little easier and live with my wonder of engineering
