Max lift for heads
Max lift for heads
Im going to be utting A set of ported 5.3 heads on a 5.7 motor. They have the stock valve size. What is the highest lift cam i can use without having to cut the piston or messing with the heads?
Also, will the ported 5.3 heads make the engine lose power over a set of stock 5.7 heads?
1-Properly ported 4.8/5.3L heads will definately add power.
2- LIFTS have practically very little to do with PTV clearance. Durations and Valve Events are what you have to watch for.
!LS1 11 Second Club
Max lift along with duration (at a certain valve event time) is what you need to be concerned about. Look a the TRak, it's .640 on the intake.
Anyhow, porting a set of 5.3's is a good idea, as you will gain compression.
The key thing is getting a good set of 5.3's from a porter that knows his stuff.
It's probably less expensive to purchase a set of 5.3's (or even a set of 243s) outright from one of the vendors than to have someone port them for you.
