Push rod length for ET 215?
Using new GM stock rocker arms and lifters. I've ordered a push rod checker but need some feed back from guys who have gone through this process already. Also, I don't think i'll need to fly cut because of the additional free drop however, how would i fly cut if needed since the only heads available for cutting are all 15*??
Thanks
Thanks
Collections Hold
11deg
Thanks
Thanks
We have an 11 degree head avalible for flycutting.
adjust the pushrod until you have between 1'2 and 3/4 turn on rocker bolt after all the slack is taken out.
then measure that and that is your length.
you may have to round up or down slight ly to get to a .050 increment.
