daily driven trex or similar cam...
ok looking into another ls1 car. im thinking the trex cam for my daily driver. my only concern is finding the right spring so that i dont have to tighten them up every so many miles. so what springs are you running and what else should i replace? ive seen people change oil pumps, timing chains? could i get away with just the cam swap and valvetrain? thanks for the advice.
basically what i want is a nice strong daily driven cam+bolt car with a shot of nitrous in the future.
LS1 Tech Administrator
Unless you are prepared to run badass valve springs and do comprehensive driveability tuning, you will not enjoy the T-Rex in a daily driver. This is an extreme cam and requires a lot of attention to detail. It's not a drop in deal. Tuning is critical with this cam. Comp 921s are some of the best springs to run. Next would be the PP/PRC/Manley duals. You'll need to shim them to within .050" of coil bind for maximum life. Again, attention to details.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
If you dont mind changing/checking the springs often, a big cam really isnt that bad for daily driving.
my g5x4 (110lsa)on a great tune was actually more driveable than my 224 cam on a 112 with a mediocre tune.
Originally Posted by Bird-Of-Prey
What's up with this?
That's what she said...
You will want to replace the LS1 timing chain, when you pull it out, you will see why
The LS2 timing chain is plenty strong and only 30 bux, plus it works with stock sprockets
SDPC ----->
I think it's crazy to to a cam swap w/out a ported pump myself. Thats like buying a bently and putting hubcaps on it.
SDPC ----->
ЯєŧąяĐ Єl¡m¡иąŧøя ™
SDPC ----->
SDPC ----->
Originally Posted by Zeus
what's this all about? Are you under the mistaken impression that we have solid lifters in our cars and need to check lash every so often, or do the aggressive lobes/lifts of the Trex actually back the rocker arm nut out over time?
If you can say your cam backed out the rocker arm bolts, you've got one badass cam
I think he's referring to the springs wearing out and having to shim them to get back his lost seat pressure.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
i just want a cam that i can throw in and not worry about the springs until they need to be replaced.
