quick lifter questions
Getting ready to install new cam and heads. Wondering if I should replace the lifters while I am in there. Car has 80,000 on it 6,000 of which it has had the current cam in.
If I do replace the lifters which kind do I get? My local oriellys has "Sealed Power" lifters for 10 each. Will these be good enough? Do I need the encased ones? Do new ones change any of the valvetrain geometry? I am swapping cam and heads this weekend so time is an issue.
I have searched and it is being retarded still....
I'm no expert and I don't even play one on TV, but my guess is with that mileage you should think about replacing them. Maybe just use a new set of stockers???
I'll read what the experts have to say about this.
Good luck on teh swap.
They looked like they were new, the only thing is the internals and I figured after 80K they didn't owe me anything. I have always used Mobil 1 and interestingly enough when I took the heads off the cylinder walls still had the original cross hatching done at the factory. Frequently the cross hatching wears off and you are left with a real smooth cylinder wall.
one thing about the cross hatch is that with the lsx motors they have a good stroke/rod ratio and a fairly tall deck height. the ideal rod/stroke ratio is like 1.8:1 i think. a stock ls1 is 1.68:1 which is pretty dang good for a stock motor.
i would get some stock replacements off of ebay for like $95, thats what is going in mine. i have seen/played with a set and they look and work just fine.
