comp pro magnum rockers
alright so looking for a little bit of input, we installed them to comp's specs with the correct length pushrods and when firing it up seemed that valvetrain noise was way more than usual. After to the comp specs it seemed like there was a little too much play in the rocker at zero lash + the half turn before locking them. then with an additional 1/8 turn (where it felt a little more "normal") noise seemed to go down a fair bit
anyone who has experience with these im looking for how much noise they made for you and if you had any other suggestions for tightening them up properly. thanks
Kevin
Kevin
Kevin
Kevin
no nothing special about the install.. they are 1.75's 3/8 stud.. i have nasty valve covers so i dont know about stock covers.. when i go home tonight ill put a stocker on so i can let you know.. they just seem so stupid loud as far as compared to the stockers.. so need a little bt of input. thanks again
you installed them incorrectly.
you need to use a dial indicator and do it to the correct measurement after zero lash. Mine was .008-.010" cold or about 1/5th of a turn. My bet is you are way too tight. Did you soak them in oil too?
