Removing oil pan...help.
Old 01-25-2006, 11:50 AM
SSU's Drunk Typing Whore
Lithium's Avatar
Default Removing oil pan...help.
2. Where is the best place to jack the motor up at? I heard bellhousing? crank snout? (safe)?
Old 01-25-2006, 12:50 PM
Z'mnypit's Avatar
YOu do realize the motor is going to have to come way up to clear the pick up tube right? The pick up tube sits real close to the bottom of the pan. The bellhousing & front pulley should be fine. If you had access to a cherry picker that would help I guess. You could then just pick up on it from the top. What exaclty are you trying to do? Id rather pull the motor than fight with trying to get it out with the motor still in.
Old 01-25-2006, 12:54 PM
Cheatin' Chad's Avatar
DON'T Use the crank snout or Bellhousing!
Use stands at the jacking points.
I too would just yank the motor from the top. It takes me about 1.5 hours to do this.
Old 01-25-2006, 01:59 PM
Lithium's Avatar
Yeah I got two jack stands on. Now I just need to raise the motor up so that I can take the pan out...
I was the idiot who left some **** in the oil pan...so now I have to drop it and take it all out.
Old 01-25-2006, 02:00 PM
Lithium's Avatar
Yeah thats what I am trying to do...just want the safest place to put the jack so that I can lift the motor up...
Old 01-25-2006, 02:30 PM
Lithium's Avatar
What else do I need to remove? I got both motor mounts undone...
Old 01-25-2006, 02:37 PM
Z'mnypit's Avatar
Prolly the trans. I would think the bell housing would hit the firewall before the motor got high enough to remove the pan. Did you leave something you can just drop the pan & raise the motor enough to get a magnet to get it out?
Old 01-25-2006, 02:40 PM
LS1TECH Sponsor
Steve Burger's Avatar
Drop the K Member. It will be easier that way.
Old 01-25-2006, 02:42 PM
Lithium's Avatar
Paper Towels
Old 01-25-2006, 03:39 PM
Lithium's Avatar
I got both motor mounts bolts out completely and I got it jacked up pretty good right now. Its not high enough though to take the pan out...what am I missing? I need maybe another inch or so.
EDIT* Nevermind/
Old 01-25-2006, 03:48 PM
Ωmega's Avatar
Lithium, you're better off doing it this way ^^^ It'll probably be easier
Old 01-25-2006, 03:51 PM
Lithium's Avatar
Yeah thats what I just rememberd...I am only going to need to drop the k member a little bit right? what do I need to unbolt?
I am seriously retarded when it comes to this stuff as you can tell.
Old 01-25-2006, 03:54 PM
Ωmega's Avatar
Everyone stubles at one point or another...I just learned what the oil pressure sending unit is after breaking it for the first time after doing who knows how many intake swaps...
Looks at it this way, after all this is done, you'll have more knowledge of the car and how it's all set up.
Now get to work and get the beast runnin!
Old 01-25-2006, 03:55 PM
Lithium's Avatar
LMAO I am trying to man I just got to drop the K member now! A little break never hurts either
Old 01-25-2006, 04:00 PM
Crazy Man's Avatar
If you dont dropthe k member use a block of wood under the bellhousing undo both motor mounts and jack it up that way.....
Old 01-25-2006, 04:01 PM
Lithium's Avatar
Yeah I got a block on wood on the jack right now that is under the bellhousing. What do I need to undo to drop the k member?
Old 01-25-2006, 04:28 PM
Lithium's Avatar
I need to remove three bolts on each side correct? where at?
Old 01-25-2006, 05:02 PM
LS1TECH Sponsor
Look at the K Member and there are 3 18mm bolts per side. Watch the steering rack and lines, Shocks and brake lines for stress as you loosen it up.
Old 01-25-2006, 05:14 PM
Lithium's Avatar
Found two 18mm's there is one 22mm or so, is that the third?
Is it in that hole in the k member?
Should I support it in anyway as I loosen them? or just let it drop on its own?
Old 01-25-2006, 05:58 PM
Lithium's Avatar
bump...also read to not remove the bolts all the way? only 5 turns?
