I cracked my timing cover? Need input please
I was removing my pulley and cracked my timing cover a bit. Is it still good or will it need to be replaced?
Also, HOW DO I GET THAT DAMN PULLEY OFF.
I used the 3 arm pulley puller and it came off a little bit. Now I can't seem to get the rest of it moving.
If you know someone that can weld aluminum they can prolly weld it for you, and the puller prolly needs to be aligned stright make sure the three bolts align with each other.
1 Post
two piece timing cover
There's a guy on the corvetteforum that sells timing covers that he cuts in two, then rewelds so that you can change cams without pulling the damper...fyi.
1 Post
nice, Thanks for the info. I finally got my cam out about 15 minutes ago!!!! How do I find out the specs of the cam? It is a speed demon motorsports install. They installed it while I was in Iraq and never got the specs.
That's what she said...
Originally Posted by -Joseph-
I'll send you a stock timing cover with your heads, I have a few extra's. Just PM me the name they were ordered under.
TSP roxxors.
Keep at it with the pulley puller. If it has moved a little bit, you've already got the hard part done!
